-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/forumdisplay.php?f=268)
-   -   need honest value on my 77 930 turbo (http://forums.pelicanparts.com/showthread.php?t=636319)
dhg1337 10-24-2011 10:46 AM
I would like to get some honest opinions on what my 1977 930 is worth .Can't hurt my feelings.
This was a fun project. I am about done with. As you know you are never done with these toys. I got my eye on something else. No I am not a mechanic. You better be if your buy one of these old relics.
I am thinking $32k:confused:
http://i147.photobucket.com/albums/r...rsche002-1.jpg
http://i147.photobucket.com/albums/r...e/0a7321d5.jpg
http://i147.photobucket.com/albums/r...orsche/064.jpg
http://i147.photobucket.com/albums/r...porsche004.jpg
http://i147.photobucket.com/albums/r...rsche006-1.jpg
at Rennsport
http://i147.photobucket.com/albums/r...e/8adc3fda.jpg
at rennsport
no service history,not original paint, so all the Germans STOP READING :( maybe just for parts
1977 930 turbo, USA model ,rare sunroof delete, AC, LSD, 90 K miles, been in California for a long time, unmodified,stock, lowered ride height, no rust, no major accidents.
Original Blue leather leather interior, front dash and rear speaker shelf changed to regular black due to warping. I have color matched dye to change, leaks a little at front shifter seal, Engine has had Carrera tensioner upgrade, head studs have been changed at one time, engine pulled, almost all gaskets and seals replaced, had one intake valve sticking, head rebuilt, replaced one cam ,had rocker arms and shafts reconditioned. engine runs great now, Turbo kicks in nicely, 0.8 bar, Innovate LC1 to keep an eye on AFR's, No Major accidents, front drivers fender may have been replaced. Original Fuchs, New tires, nothing fancy, just original size. Car is as clean on the bottom as on the top. All gauges work, auto heat works. Car still needs a few things, alignment, bit off from when I changed the front Koni struts. Brakes though new need a little tweaking. Only driven it a few times, brakes get better each time i drive. pretty smooth on the hiway.alignment should be offa little from when I changed the front Koni struts but it goes down the road straight and no wobbling. Camber is probably off, but not noticiable.
Here is a list of stuff:
Extensive top to bottom restoration. If a part was worn or none functional it was replaced with good used or new parts. All rusted or poor looking parts where bead blasted and painted. AC equipped originally, missing compressor and rear lid evaporator.
Head studs changed at one point in the past, now steel, magnet sticks to them
Engine had great compression tests except for #6. The intake valve was not closing. Engine/transmission pulled. Oil tube in cam carrier was plugged. Hole is normally the size of a needle. This caused the valve to become stuck open due to lack of oil. One cam reground, 6 rocker arms, 6 rocker shafts refurbished, by Dougherty Cams.
#6 head rebuilt, by German Precision
Engine runs smooth, sounds good, no smoking from exhaust.
Runs cool
All engine tins, brackets, aluminum, steel parts bead blasted and painted.
If taken apart all new gaskets and seals installed
2 new oil return hoses from engine to thermostat
2 new oil return tubs
New starter
New battery
Carrera cam tensioner upgrade
Smog pump, tubes, in place, new check valve, new smog pump filter, passed California smog easily.
New thermo sensor, newer cold start valve
newer boost sensor
New oil pressure warning sensor
6 new fuel injector blocks
Fuel injectors cleaned
Turbo rebuilt.
Original exhaust, all professionally rewelded
W pipe headers, all gaskets new, thermo reactors gone, bad for motor
New Exhaust studs
Innovate LC1 wide band AFR gauge
New oil tank sender gasket
New spark plugs, rotor and cap.
New fuel filter
New fuel accumulator
New air filter
Engine detailed, while on engine stand
New Main oil lines from engine to thermostat.
New Silicone valve cover gaskets
New Diverter valve seal
New engine belts
Carrera front oil cooler added, new outer air seal gasket.
New heater duct hoses
BRAKES:
New brake fluid
New rubber
brake hoses.
New rear rotors
New front and rear brake pads
All brake calipers detailed
New front wheel bearings, races and seals
SUSPENSION:
Steering tight, no play, smooth on the hiway
New steering wheel bushing
New rear sway bar bushing
2 new front sway bar bushings
New front Koni strut inserts
1 new steering rack accordion rubber
New Yokahama S sport tires, original sizes
Original Fuchs wheels, repainted black portion
TRANSMISSION:
Shifts well, no grinding between shifts, mild 4th gear whine, has small leak at front shift shaft seal
Clutch disc was ok, within limits, not replaced.
1 CV joint replaced, others inspected, cleaned, repacked with grease
New CV joint boots, new gaskets
New clutch helper spring.
New shifter bushings
New transmission coupler bushing
EXTERIOR: brand new
brand new paint, very nice quality, original color, front fender at one point was probably changed, reason for the Euro side marker. No major damage anywhere, no rust, underside detailed.
New front hood struts
New front and rear window seals replaced
New front windshield
New front smile
New rear bumper guard strips
New rubber seals for body parts
New body gaskets/welts
1 new bellows
New outer window felt
H1 headlights, rings rechromed
New Porsche hood emblem, have original
New wiper blades
New Euro rear fog light not pictured
New hood struts
New power antenna
Outside mirrors glass replaced, motors and defrost work
New windshield washer pump
Horns detailed, very loud now
INTERIOR
Overall in excellent shape for 34 years old, no tears, all gauges work, auto heat, all knobs function
Dash and rear speaker shelf replaced with standard black, has 1 inch
crack in dash near window defroster vent.
Original blue leather interior, touched up a little
with color matched dye.no tears, no bad areas
Carpet original, very nice condition
Original gear shift knob
After market stereo, CD player, nothing special
New electrical part of ignition switch
Steering wheel column bushing repaired
New rear wiper switch
Have original tool kit, spare tire, air pump,owners manuel, trunk carpet very nice condition.
Due to the age of the car and being used as a daily driver it needed a lot of work, many parts where exchanged with newer/better used parts, these parts were not listed. Have receits since 1 1/2 years I owned it , nothing before.
dhg1337 10-24-2011 11:16 AM
click on this if you want more pictures
http://s147.photobucket.com/albums/r317/dhg1337/porsche/
cellison 10-26-2011 06:05 AM
seems reasonable @ $32k given the description. postive to me it's stock since the 76-77s build numbers are low. i have seen others asking not much lesss money that you are and the cars were not attractive.
jr993 10-26-2011 01:54 PM
Very nice. "USA Model" with euro-sidemarkers? Seems like prices on these are stronger than they were 10 years ago.
dhg1337 10-26-2011 02:15 PM
It is a USA model, per vin # Thats why I wrote one of the fenders may have been replaced. Need to add one on the other side. Can't be perfect, that going to cost more.
Can anyone ID what else is not correct on the outside.
Dan J 10-26-2011 06:03 PM
If your car is as good as it appear it's worth 32 all day. I think the early Turbos (75-79) especially real clean stock ones, are going to be really strong going forward. If you've got time I'd ask 36 I think you'll get it
Macroni 10-27-2011 10:37 AM
These cars are artwork. I agree $32 is reasonable.....
cellison 10-28-2011 06:45 AM
i agree. put it out ther for $36 and see what happens. more than liley you will get folks from EU calling. there are just not many 3.0s for sale.
