-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/forumdisplay.php?f=268)
-   -   What is a reasonable value for my 68 912? (http://forums.pelicanparts.com/showthread.php?t=802669)
912porscheguy 03-23-2014 07:05 PM
As earlier promised , I have a new thread showing my car which I'm considering selling. It's not perfect, but here it is. Mechanically; weak first gear sycnhro, sputters a little on startup (jetted lean for my altitude 5000-6000 feet), cosmetically, some touch up areas of paint (paint job over 20 yrs old), some minor rust repair to rocker area below both doors and passenger side fender, No return of rust in last ten years, 3 inch crack in front piece of dash ( 68 is a two piece), one inch rip in knee pad by glove box, some wear of drivers armrest, minor dings, chips and scratches as expected with use. I just added Hella fog lamps yesterday (not Porsche OEM style), but no pics yet. Currently running Webers with original 061 dist. with Pertronix igniter. Driven less than 3000 miles in last ten years. Used for special getaways and light neighborhood cruising. Odometer stopped at 67310, and was immediately sent to a guy in Manassas, VA for repair. Current mileage under 68k. Photo link 1968 Porsche 912 - Imgur. Welcome all honest assessment of my cars value, if I can bear to part with it. Thanks for any advice and for looking!
aircool 03-23-2014 07:32 PM
Pricing
The value depends on who on this forum you ask. But don't take any estimates seriously, since this forum has no influence on what you ultimately sell your car for. Put your own price on it and roll the dice.:D
Really though, there are a lot of knowledgable guys on this forum, others are out of touch with the real world, but have good intentions. Check the internet for car similar to yours and then price yours higher. A lot of forum members from NVA can give you a better idea of local market. Also depends on how quickly you want to sell. Need to think about timing and $$ you put in to it. It may be wise to sell before you get upside down.
Good luck.
SilberUrS6 03-24-2014 06:27 AM
Longhood SWB cars have been going nuts the last couple of years. The primary issue is rust. How much rust the car has, and where, really determines the value. The 912s have been lagging a little, but have come up in price nicely in the last year. If the car runs well, with no mechanical issues, $22-26k.
pors1968 03-24-2014 06:20 PM
Can you post pic inside truck and body and 5 first digit serial number.
Matt Monson 03-24-2014 06:50 PM
I hesitate to offer a value because I'm really unsure of how quickly the SWB market has been running up the last 6 months. But I think you would be giving it away and significantly underpricing it at $25k.
pors1968 03-24-2014 07:08 PM
I did not see the link nice under body .I would rebuit mecanical pump they are kit for these but 28-32 with couple thing fix pump- seat.
912porscheguy 03-24-2014 11:06 PM
Response to info and questions re:1968 912
I posted some 90+ images on imgur. Will see why all did not go and will repost with link to folder. First five numbers of Vin 128031. Let me know what value that knowledge is. Porsche registry info tells me its a 68. Original color per plate on door jam was Bahama Yellow. When I replaced rear signal gaskets I could see some original color. I have had some PM sent to me and appreciate the interest. I have considered replacing the passenger seat bottom cover, and still may do so. Have seen vinyl replacement cover available on EBAY. Although the car runs fine and accelerates well, if I can find a shop I can trust, I may have a compression/leak down performed. Any prospective buyer deserves that information. Besides, since I haven't driven it frequently enough, I would like to have that info to help determine the price. I would expect any prospective buyer to conduct a PPI, and in a small sense some you responders are providing a little pre sale inspection with your suggestions. Greatly appreciated! Keep the comments coming.
912porscheguy 03-24-2014 11:33 PM
Oops! gave first six numbers of vin, duh! It's late.
pors1968 03-25-2014 03:03 AM
Your link work fine nice car with little TLC you will be upper braket price.
mark waller 03-25-2014 07:23 AM
I believe the 68 also had side marker lights. I did not see those in the picture. If someone is looking for original, that might hurt it a little. You said the paint job was 20 years old and they might have removed the lights then. You still have the 68 door panels that were for that year only. I think the prices offered in the $20's seems about right
Matt Monson 03-25-2014 07:30 AM
If it was a euro car the markers never would have been there. What's the engine type and number? This will tell us.
The color change dings it a bit but the original color is a great color that I suspect someone will want to take it back to at some point.
912porscheguy 03-25-2014 09:58 AM
response re:68 912
The engine number/ case third piece number as I recall indicates engine is from a 69, so may detract from value not having matching numbers. Will post number when I return home. I think markers were removed prior to repaint, but I didn't see any evidence of holes or wires where they would have been removed. I have what appears the original owners manual, printed in 7/67, along with the emission manual, so I think it was a US/Can model. Amazing how little I know about the car! Ten years of ownership and still learning. Thank you all! (my wife just texted me with numbers 616/40 engine type, so 69 with emission controls. engine number possibly 4093012 (hard to read clearly)
912porscheguy 03-25-2014 10:06 AM
Also, the mechanical fuel pump works fine. I just installed an electric pump with a regulator, to save starter from long crank times to refill carbs between usage, as long as two weeks between startups. However, weather is turning nice. I'll drive it more and may remove pump to keep car as original as possible.
wgwollet 03-25-2014 12:15 PM
Hello
912 Porsche Guy
I have owned a few 912, they are a wonderful car. Your looks very nice, I find pictures do good and bad but based on your description it should bring the mid 20's not to say you couldn't get more. There are two on Samba at 33k and 35k....this is where good 912's are going. The 1968 is the least desirable because of odd year and interior BUT do not worry T's a moot point. Condition with NO RUST EVER OR NO KNOW ACCIDENTS TRUMPS ALL....yes engine rebuilt and good interior is a plus but the body will drive the price.
Cars that claim to be RUST FREE usually are not, but a true no rust original car with original pans and caps will constantly go up in my mind.
wgwollet 03-25-2014 12:17 PM
Oh, non-matching engine could hurt your car 20%, my above comments were for matching numbers car and the correct color repaint....
pors1968 03-25-2014 01:39 PM
Ok with most of facts on vehicule even with non matching engine and color still a nice car but little less from my above comments like the car 22-26k
Matt Monson 03-25-2014 03:20 PM
Non matching engine is a big ding. Removed side markers hurts a bit too. Maybe $25k isn't so far off the mark after all the dust settles.
NYNick 03-26-2014 07:59 AM
OMG…$30k plus for 912's? Where is this market going?
912porscheguy 03-26-2014 08:27 AM
I too am amazed at increase in value of the 912's. However, just allowing for inflation, and not factoring in condition, $4900 in 1968 (approx. cost of a new 912 then) is the same as $33, 685 in todays dollars, so 30 - 35k is actually not unreasonable. I doubt my car would bring that, but as demand increases and supply dwindles, market forces always win out. Absurd, I, know,but it is what it is.
pors1968 03-26-2014 11:21 AM
For 30k you will have to find the right buyer who have no concern about matching number right color rebuilt the weak first gear side marker(650.00 ) and other things.The right buyer is the one who will enjoy just a nice ride.
912porscheguy 03-26-2014 01:28 PM
In total agreement
In it's present condition, I wouldn't consider trying to sell my car for 30K. That's why I asked forum members to help evaluate the car. I appreciate all the input I have received and feel the responses have been genuine and frank. Thank you all very much!
NYNick 03-27-2014 04:04 PM
I'm just bummed I sold two of them for $5k, albeit a long long time ago!
912porscheguy 03-27-2014 11:40 PM
response to NYNIck
I guess hindsight truly is 20:20. I sold a 69 912 15 minutes after I parked it near the Hospital I worked at. Paid 1700 for a pretty rusty car, put 2k into it, new paint etc ( 2nd car I ever painted.. was gorgeous), and sold it for 5500.
This was in 1990, though. It was a factory sunroof model, only 417 made. Ah well, I'm sure many posters have similar tales of woe. I once sold a Fiat 1959 1200 cabriolet for $1500, I paid 50 dollars for in pieces...owner was using radiator as passive heat exchanger to heat pool, chassis number 103. Restored it. Today, same car worth over 20k. Capitalism at work, i guess.
Matt Monson 03-28-2014 07:23 AM
A couple years ago I gave one away...
NYNick 03-28-2014 02:03 PM
No offense meant to 912Porscheguy and any other 912 owners, but $30k plus for a 912 is territory that is hard to believe. Back in the mid 1960's, these cars were built to satiate the US owners who were pissed off about the 4 banger 356 going away. The factory was concerned that the 6 cylinder cars with a new body style wouldn't take off, or that customers wouldn't pay a substantial premium for the 911. That's why, once they did, the 912 was discontinued until the oil embargo a few years later.
It was a poor man's 911. If you're 'poor' today however, you not buying a 912! True, there's a lot of value in the (911) chassis, and dependability in the (356/VW) engine. But it's not and never will be a 911, with 4 cylinders behind you.
BTW, two 912's were my first two Porsches. They were why I fell in love with the brand, and the reason I'm a Porsche fanatic today. They were very, very cool cars for the money, but at $30k, I'll try another Porsche model, thank you very much.
NYNick 03-28-2014 02:12 PM
Might I add, I'm with you 100% 912Porscheguy, and I hope you do well with your sale!
Nick
