2.7 blank motor case
Complete engine running condition 74 heads and 74 cis system what is fair value for this engine with replacement case Merci
With no known receipts, leakdown, or anything else that might help you or the potential buyer, I suspect it's realistically worth $2500-$3200 depending. That is, if the leakdown is good. A 2.7 is as good as a core if there are that many unknowns.
CountD is spot on, value wise.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Does replacement case or blank add some value.
As a bare case, perhaps, but as part of a complete engine, not so much. The parts inside are indicated by the stampings and the blank case creates a question.
Thanks .Merci
