Still here
pmax's Avatar
Another one bites the dust ?
1988 Porsche 911 Carrera - coupe w/ G50 (body work needed)
$17500
Old 05-20-2015, 04:58 PM
ptrsbtrs
peter leinberge's Avatar
That ain't nuthin to be a-scared of.
It's just metal, not an arm or leg
(although it might take one of each to fix that)...!
Old 05-20-2015, 06:06 PM
Broke
Westy's Avatar
Well,,,,,,the glass didn't break!
Beer is proof that God loves us and wants us to be happy. B. Franklin
93 968 Cab
81 SC Targa (Princess) Now Residing in Denmark
1973 RS Z28 Vash will never own it!
Old 05-20-2015, 08:18 PM
gearhead
That car will be fixed and back on the market in less than 90 days.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-20-2015, 08:31 PM
Cars and Cappuccino
tdw28210's Avatar
There is value there.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 05-21-2015, 04:35 AM
Eva
911SauCy's Avatar
Interesting how the fender is so crumpled and the glass and wheels are untouched...
My gut tells me it's quite a bit more than a flesh wound
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 05-21-2015, 05:46 AM
Farrell's Avatar
^^ i agree with this, i can't imagine its just the quarter that needs replacing.
Old 05-21-2015, 06:05 AM
Mo money = mo parts
The damage is not likely impacting the tub, but I would bet that the banana arm needs replaced. My car had the rear quarter replaced somewhere in it's past. It took me several years to sort the issue because the banana arm looked fine, but the hub end of the arm was bent by about two degrees which created issues that seemed like there was a problem at the spring plate mounting.
I have read that there's a factory jig to test swing arms, but as you can imagine there are probably about five in the U.S. - good luck finding one close by. In the end, I took a gamble and swapped the swing arm, and that fixed the issue. I took before and after measurements of the wheel camber which is why I am confident it was bent, plus my problem was fixed.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 06-13-2015, 03:54 AM
