915 Value
I believe this is a 72 or 73 Transaxle. One thing for certain is it is the only year where the input shaft seal has be installed from the inside of the box.
This box was rebuilt about 10k miles ago with the new input shaft seal and 1st and 2nd gear syncros. It shifts very well and was in my "daily" driver. The numbers on the bottom don't appear to be all there due to some scratching. From what I can make out it shows 7331671 What kind of value would this trans bring? ![]() ![]() ![]() ![]()
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/showthread.php?t=410787 Interior - http://forums.pelicanparts.com/showthread.php?p=4433500#post4433500 |
I recently sold a 'core' for $1200.
Most valuable thing in that box is the ring and pinion, which can be inspected with very little labor.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
gearhead
Ring and pinion and the TM 5th gear. Those two things together are worth about $1500 on a bench. If the 5/r op sleeve is good, that's $500 part new, $250-300 used. Speedo drive tail cone is $250-350.
If you inspect the ring and pinion (pull the side cover) I wouldn't sell it for less than $2000.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Is there something unique about this particular mag box or just due to being a 7:31?
How may i verify it having a TM 5th?
gearhead
It would be worth more if it was a 74. 72, 73 don't have a removable guide tube. The case is uninteresting.
Most of the money is in the ring and pinion. You cannot verify the 5th without pulling the tailcover. But it's only about 8 nuts. And you can verify 5/t slider condition at the same time. Most guys won't bother and offer the box as a maybe at $800-1000. You can get double that if you show it has some good stuff inside with half an hour of wrenching.
Thanks for the info, that'd definitely be worth the time.
