...and my blue mistress
Feeler and Pricing advice for 3.2ss I'm considering selling
Hi guys, I am looking for a little advice on price for my motor I am about to post up for sale. It is a 3.2SS Not really a long block because the only thing it doesn’t have on it is the intake. All that described below. I’ve seen what various versions of 3.0l motors go for around here and all of the related uncertainty related to build/rebuild dates, running or not, documentation etc… But this one has none of that uncertainty and I built it with a spare nothing approach. It’s not my first rodeo either. I have pics of the entire build, receipts for almost everything I put in it or on it, fellow Pelicans I share shop space with that have ridden in my car and even driven it and know this motor well.
the full description is below as well as some of the pics I was planning to use. I’ve spoken to me other folks who are currently having a 3.2ss built and they are all telling me they are in those for 25k. I’d like to sell it quick but not lowball quick so I was thinking 19K. If the buyer was in the Atlanta area I have the facilities to help with the install as well. Let me know what you think. I didn’t want this to appear one of those “laughing at asking prices thread” we have going on around here. Thanks! Robbie [B] 1st the obvious thing- This is more than a long block and contains literally everything you need except intake. I ran 46mm PMOs on this and the dyno results were done with that setup. Buy a set and bolt them on and you are done. I’ll give you all the jetting & choke sizes I was using too. Based on the size of the in and out ports as well as the cams and 1-3/4 headers, this thing would probably benefit well from even 50mm carbs or EFI. I say that also because when we tuned it we kept adding bigger jets until we ran out and it was still looking for more- like a hungry monster. Built in 2014 and the motor has around 3,500 miles on it. Single Plugged runs and happy on pump gas. Never been raced and never been on track. It has of course been opened up and well enjoyed in that spirited way it should driven. Dyno tuned- 252.10 HP and 224.32 TQ at the the wheels. -Dyno attached Started from open case- cleaned cleaned cleaned and then cleaned some more… Every component in there was cleaned with that kind of attention. I spent easily 10 times more hours and $ cleaning it then I did actually assembling. All components measured for tolerances All gaskets, bearings, seals, chains, any thing with gears or teeth replaced if any prior signs of wear. All case and valve covers hardware replaced with new. All mounting studs for all hardware either replaced or chased. Most replaced as it was easier. Nothing leaks, no weird noises, and flat out a blast to drive. Power comes on around 3k and never stops. All head studs are steel and OEM new Rods inspected and pin bearings replaced by Ollies. ARP Rod Bolts All rocker arms replaced where needed and all rocker bushings are new. New Oil seals on each. Spray bars replaced with new. 98mm Cylinders from EBS Racing 98mm JE Pistons- 9:8:1 DC40 cams- power comes on hard around 3k and just keeps going until you stop Carrera 3.2 head-with a little massaging + built with new seals, guides, springs retainers... Stomski Racing solid tensioners. New alt with internal VR Magnecor plug cables MSD coil and CDI Single Plugged Dizzy and runs happily on pump gas. New Clutch & Pressure plate. All engine tin, fan housing, and mount bar Powder coated black. 1-3/4" headers.
Robbie 1976 Carrera3.0 1978 928 5spd Last edited by mazing3; 04-22-2016 at 09:19 PM.. |
19k is very fair for a documented build with verified dyno numbers.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Eva
I'd go 15k considering the engine may have run well when 46's were on it, but they're not any more and the fact of the matter is it's incomplete and non-running engine. Also, the piece missing is a substantial expense.
I recently had an opportunity (didn't have the coin) to buy a 3.2SS, twin-plugged, w/ PMO's, with less miles, making almost identical numbers, for $17k installed...
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Thanks man and your timing was strangely good... I was just thinking about this very thing and was going to drop the price in a few. I too was thinking 15K. - specifically for all of the exact reasons you pointed out.
Then I did some asking around and started hearing some crazy numbers and that is the exact reason why I posted it here for some advice. Thanks again SauCy. I appreciate the advice
Robbie 1976 Carrera3.0 1978 928 5spd |
robbie,
I'd say that $15K is a very good price for that engine. The addition of recent leak down numbers would be a good thing. regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Thanks Al! I've got all that too. Good advice.
