Olsen911's Avatar
Weber 40 for Porsche 911
Gents.
Have this set - bought a long time ago - never tried them on.
I think it´s all there - and it should be assessed as cores.
Can anybody id the year for these.? and they value.?
Thanks - Cheers - Tommy.
“I will not demonstrate it, I will race it.” Juan Manuel Fangio
Old 07-04-2016, 04:46 AM
Right below the Weber on the carbs are some stamped numbers you'll need to post to get an idea of the model of carb. There is also a casting date on the side of the manifolds. It'll be a 66, 67 ,68 or 69 with a bunch of dots around it that indicate the month. Post those and a more definitive answer can be given.
Old 07-04-2016, 09:01 AM
Olsen911's Avatar
Weber 40 - Porsche 911
Thanks.
Here is what i belive is the Numbers on the Webers.
First: 40IDT3C
Second: 1735
It says: 68
First: 40IDT3C1
Second: 1979
It says: 68
Let me know what you guys Think.?
Old 07-04-2016, 09:34 AM
IDT's are lower in the triple Weber 40 totem pole.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 07-04-2016, 11:51 AM
yes, there were three Weber triple throats put on two liter 911's. IDT, IDA, and IDS. IDT's are the least desirable and IDS are the most desirable. The IDT were put on the detuned 2.0 911T, the IDA were put on the standard 911, and the IDS were put on the '67 and '68 911S.
Old 07-04-2016, 12:07 PM
Olsen911's Avatar
webers Porsche
Thanks.
What would the value be of these IDT.?
Old 07-04-2016, 09:10 PM
As a complete setup with air cleaner and crossbar I would say in the neighborhood of 2K plus or minus a few hundred. IDA's I'm more familiar with and those generally go for around 2.5K plus or minus as a complete setup.
Old 07-05-2016, 12:28 AM
gearhead
IDT's are from a '68T. I would agree $2k or less.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-05-2016, 06:09 AM
gearhead
Here's a comp on just the carbs themselves.
http://forums.pelicanparts.com/porsche-914-used-parts-sale-wanted/920192-fs-weber-idt-carbs.html
1974 914 Bumble Bee
2009 Outback XT
Old 07-05-2016, 09:22 AM
