914-6 motor
Hello, trying to help a friend put a value on a 1970 914-6 motor. It is a correct motor as validated by serial #. It is complete but partially disassembled down to the long block. It has been sitting some time and will require a full rebuild. It does include the correct Zenith carbs.
Thanks, Joe
Old 08-15-2016, 07:47 AM
911, 914-6, 928
Please post the serial number off the case. It will be worth the most to the owner of one certain car.
Old 08-15-2016, 08:36 AM
Correct Carbs are Webers
All my reference material specify Weber carbs. I have a 71 factory six with Webers on a numbers matching car. Please check your reference material.
Gene
63 B coupe
64 SC sunroof
912 coupe (current)
914/6 (current)
Old 08-15-2016, 11:28 AM
So, I guess these are not the correct carbs...
A few pics below
Old 08-15-2016, 01:25 PM
911, 914-6, 928
Value
Thanks, Joe
As a non-number matching 911T engine core, maybe $2k - $3k.
To owner of the number matching 914-6, IF IT COULD BE FOUND, it could be several times more depending on how nice the car is currently.
My opinion.
Old 08-16-2016, 05:43 AM
It isn't a T engine. The serial number is for a 914 six cyl. The carbs are from another planet. Check 914 World site for serial numbers wanted.
63 B coupe
64 SC sunroof
912 coupe (current)
914/6 (current)
Old 08-16-2016, 06:00 AM
911, 914-6, 928
While not serial numbered as such, the 2.0L 914-6 engine is the same spec as a 1969 911T 2.0L engine. A 911 restorer may value it for their car.
Old 08-16-2016, 11:35 AM
