Early Repa seat belt question and value
So I purchased some seat belts for the back seat that I thought would work. I was told they came out of a 914. After I got them I found the correct seat belts. I want to sell these but I want to make sure I list them correctly. The belts have 911 part numbers with 1968 & 1969 years. The receivers are missing a tag on one and the other is a 914 part number with a 1970 Date.
Are these a mixed set of belts or are the 911 & 914 part numbers correct for a 914? Should I sell them separate or together? Fair value? Thank you. ![]() ![]() ![]() Sent from my iPhone using Tapatalk
Derrick |
Mighty Meatlocker Turbo
Deez, the two on the left are definitely the very early, non-retractable-belt, 914 receivers (you already knew this), and the two on the right look like 914s as well. I'll be your daddy and check the PET for part numbers in a little bit, bro!
OK, all of the seat belt part numbers listed in the 914 PET (all years, and including 914/6s) begin with 914, so the 901 part numbered halves are likely not originally from a 914. Last edited by Rawknees'Turbo; 11-07-2016 at 09:05 PM.. |
Thank you. I guess I could list them individually incase someone needs to match a single belt to make a set.
Derrick |
