Dave W
$85,000 motor. Educate me...
I have seen some expensive motors before, but they usually are very rare or extensively built race motors.
Can you educate me on this one? Is it that rare/ special?
1975 911S (3.2) "The Blue Goose" 1978 SC 3.2 track car |
disband
it's gotta be the tennis balls....
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
gearhead
It's a 73 RS engine. Their story doesn't completely make sense and it's not 100% stock. but to someone with a real RS with no engine it would be worth a lot.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
In my experience, anything made in "small batches" is more expensive, be it beer or kettle chips
Troll Hunter
Matching numbers RS' are worth what? $500K-$1M? Like Matt says, if you've got one with no engine, even though it's modded, it's worth a lot.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
gearhead
I’d like to see their documentation that it’s from a complete replacement engine. Replacement cases are generally instamped until used. And the number is in the last 200 engines made, not all the way at the end.
Why so secretive about the engine number last two digits? Seems really odd - if the factory says it was never assigned to a car, why does the full ID need to be hidden? Maybe I'm missing something.
1996 993 Coupe, Tiptronic, Polar Silver 1973 914 1.7 Marathon Blue Metallic - Sold 1977 911S Targa - Sahara Diamond Metallic - Sold 1975 911S Targa - Copper Brown Metallic - Sold |
gearhead
Yep. That's one of many odd things about it. And look how filthy that is compared to the 911/83 picture. So they took a picture of the serial number dirty before the rebuild but the type number clean after? Makes no sense.
Thoughts...
1) If it were never assigned to a real RS, then what's the difference between this engine and another 2.7 7R case (replacement or otherwise)? If you built a 2.7 7R mag case with mech. injection and 2.7 cylinders, in my mind there is nothing really special about a RS engine, with the only exception being what does make it special is when its installed in a numbers-matching RS CAR. 2) Assuming it is a real 66313XX (911/83) engine - let's say engine #1350 as Matt assumed, placing it in the production order of number 1350 out of 1551 engines, then it would only be special to someone who 1) had the car, 2) knew the engine was a backup run in there car, or 3) wanted a cool backup to their vintage racer (possible). 3) I do not see the value, nor the thing about disguising the last two numbers. I would have just disguised everything after the 663XXXX. There is nothing special about this engine. A 911/83 engine is a 7R mag case with 2.7 Nikasil and mech. injection. |
Functionista
Well nothing too special. It came with the black nitrated rods same as the 2.4S and throttle bodies had larger idle bypass passages. Ignition advance curve slightly different. I don’t believe the blocks or MFI pumps were hand selected out of production for any special reasons (California MfI cars did receive the most accurate pumps to help pass emissions). The pistons were forged like the Carrera 3.0 and 2.4S. Nothing that can’t be built today. Good street manners, not peaky. Best suited for lightweight cars with lower gearing IMO.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
gearhead
A 73 RS engine is basically a 2.7l S spec engine for most comparison purposes, and a lot of shared parts.
