72 Mango Green hot rod
Hi,someone requested a picture so here it is.The B pillar as well the targa bar is two 1.5 inch tubing with metal added between.I wanted to create the roofline for the targa to clean it up and stiffen the chassis.Short stroke 2.8 66 x 95mm with 3.6 heads.45 mm Slide Valves with Motec.Ti rods & valves.374 H.P.at 9300 rpm.249 ft lbs of torque.Car is a little less than 5 lbs. per H.P.
Fred that Targa bar looks really sweet. I like what you've done with it.
Excuse me.. did you say 9300 RPM?!
![]() Your car looks and sounds like a lot of fun. I'm sure the look really freaks out the squares (also a lot of fun) |
gearhead
I’ve got a single 914 seat in that tartan. I’ve always wanted to put it in my signal orange car.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
yeah, i just put seats in my 914 with that tartan. crazy...
1971 914-6 GT 3.6 1974 911 1976 911S leaf green backdate 3.2 |
It's a 914 ...
Very nice, Fred
The 9 Store
I want a ride - Please
All used parts sold as is. |
I also want to ride!
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
motor
Hi,to answer a question the car does not run on pump gas.Compression Ratio is 14.31.This is not a DIY Motor.Wussies from California who want 93 Octane do not read this post.Pistons are Mahle Roitmeir that were12.5 to one.With the rod being longer at 132mm the deck is set slightly higher to compensate for the expansion.I am building a new short stroke with 66 x 98 for 3.0 with a 22.5 lb.forged chrome-moly crank with Ti rods of course.Will post soon.Thanks for your response.Ciao Fred
That looks cool!
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Wait 1870lbs! How did you do that? That’s crazy.
78 911 st backdate 87 944 00 996 |
And less than 1870lbs?
If you give your word: keep it. |
light weight
When you remove 4 pieces of glass.4 torsion bars.Gas tank.No wiper motor assembly.Doors were acid dipped.Magnesium center BBS.Boxster 4 piston calipers.Lexan windshield.Light recaros.Complete stainless exhaust.RSR aluminum rear shocks with Titanium springs.911/01 gearbox with Titanium spool instead of boat anchor differential.One light battery instead of two.ATL fuel cell it sheds weight pretty quick.I will be adding a second cooler to the right front fender when I remove the slant nose kit as H.P.makes heat.Turbo tail is going away for a 964 cup rear lid.Car was built in the 80,s when a T Targa was worth nothing.Yes the purists cringe but I like the lines of it plus it goes down the road very well.
I'm all smiles - must really be a kick
