Why so cheap?
Why are the earlier - 1977 2.7 liter 911’s so cheap?
Have a chance to get a repainted ‘rare’ blue 1977 with 30k miles on rebuild and no rust for about $25k There is a yellow one that was also posted in seattle Craigslist yesterday for $25k What makes these the least desirable? |
Kind of Blue
They utilized thermal reactors for emission control which tended to cause the engines to run substantially hotter and warp the heads over time. The "mid-years" were considered the stepchild of the air-cooled 911s for years as a result.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Here we go again...
non-whiner
The 2.7 with the stock exhaust removed and an appropriate aftermarket installed, Carrera tensioner, etc. is a reving monster. While light on HP, they are a blast to drive. Many still see them as underpowered impact bumpers, where the SCs and Carreras are better. I disagree as long as you are willing to make a few improvements.
"Too much is just enough." |
disband
most of the states that require emissions testing, CA & CO come to mind off the top of my head still require testing on the 76 & 77 models so they are less desirable for the items noted above.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Ahh okay I've heard people skim the subject but no concrete answers. Thank you!
I've got a chance to get a 1977 911S for $25k Has 125k on body, and 30k on engine rebuild. No rust and had bare metal repaint to original paint code 304 (caribe or manerva blue?) Only issue is cracked dash and a window switch needs rewired. Thinking about pulling the trigger. Let me know if any interest in pics. |
non-whiner
You don’t know us very well. We are ALWAYS interested in pictures!
-pulled head stud issue fixed. -no thermal reactors -add SSI -add sport exhaust -add pressure fed carrera chain tensioners -pop off valve -11 blade fan, not the 5 blade. Everyone talks about originality is valuable in all air-cooled 911s. Not true with the 75-77. Nobody wants one with thermal reactors, stock exhaust and 5 blade fan. All my listed mechanical upgrades add to the value.
The present: 83 944, 77 911S The past: 95 911, 67 912, 76 912E |
Wow, I passed on a 77 911 Coupe in green with only 45,000 miles in excellent condition that had recent top-end rebuild for pulled head studs back in 2006.
Asking price was $14K and I thought it was too high at the time and picked up my 82 Targa a few months later for a little bit more. Took the seller about 2 years to find a buyer.
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
non-whiner
Yeah, well I also sold a 1986 930 with 42k miles for $34k six years ago. I try not to think about it. At least I know it went to a great home!
gearhead
If I were in the market, I would be kicking the tires on Ficke's 77 Targa in the classifieds. I think that's a nice car and the money on it is right, $32k.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Asked the seller if any of this was done. Now I feel even more pissed the local guy to me sold his 77 911S with a 3.0 in it and an added well-done SC wide body... Oh well. If you guys wana get even more upset google some older 2008-20012 for sale ads LOL |
I thought I'd be getting different flavors of air cooled 911s for $20k forever. Maybe even splurge for a $30k-$35k 930. Everything changed for the worse around 2012-13. In '15, I bought my 93k mi 77 911S coupe for $25k.
Stay focused guys. What about the same color 1976 912 with 125k original miles and original motor/trans?
They also have these issues? Have chance to get one at $20k Let me know it’s the same color as the one above! Weird |
A few years ago no one wanted the mid year cars. They are all that is left that’s affordable. Not many left as a lot of them were junked out, because of the previous low valuation. As far as the engine goes, the main problem was the twisting cases, not warped heads. Yes the exhaust valve guides failed very quickly, but not the entire head. The thermal reactor cars ran very hot in order to pass smog. Most of these cases not only pulled studs, but the cases really deformed. Most likely would need to be line board, and have the spigots re surfaced, along with inserts and steel studs. If you build them right, and don’t over heat them, the 2.7 is a very nice engine, and much lighter than the aluminum alloy engines.
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke 1973 1/2 911T S optioned sunroof coupe (in progress) 1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels 1999 996 Carrera Cabriolet |
Sheesh.. I have a long way to go with porsche knowledge
gearhead
It's basically a 914 engine. Different beast.
The blue 911 is nice. That wing will not look good in person on a narrow body though. Get the car and remove the wing.
