Go Back   Pelican Parts Forums > European Car Forums > Saab Technical Forum
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
93 9000 turbo turbo and head with pics
Hello out there!
I have taken time out from my normal Porsche duties and and have taken on repairs to a 94 9000 turbo. The original diagnosis was the turbo had given out, As I have gotten into the job little hints like a quart or more of highly concentrated coolant in the oil pan lead me to believe that the head is Questionable and so....It seems that as long as I have the turbo and the ex manifold off I will be likely removing the head. IF anyone Else can think of any other reason besides a bad head or gasket that would put that kind of concentrated fluid in the pan....Jump in and let me know.
It all started many years ago, or so it seems to me, when the owner of the car brought the car to someone else to have the head done. The work done was good enough for the time. Upon examining the quality of the job as only a trained mechanic can do on dissasembly....It seems that a few small but critical parts were installed incorrectly. On this model, and many tothers, oil lines and coolant lines are steel tubes fastened to the block or turbo or pump with banjo bolts and sealed with crush washers. These washers are very inexpensive and should be considered a one use item as they crush to form the seal. Well, the PM was either unaware or uncaring of this fact and re used the old ones, even flipping a few around and forgetting several altogether. This led to a very small, almost imperceptible coolant loss which seems to have caused multiple overheat incidents. Additionally there was a small exhaust leak that may not have even been known about as several studs and bolts ere installed incorrectly.
At first I was informed that the car overheated once, when the turbo blew. Today I learned that the car was overheated several times and brought back to the same shop, who found nothing. over the course of time, many dollars were spent at this shop and still no one caught the previous mistake OR attempted to correct the random coolant loss or overheat condition.
In short....We competent and professional mechanics are a dying breed.
All I can do now is pull the head and cross my fingers that the 2.3 liter motor which by all rights should have a hundred grand left on it can be saved somehow. THOUSANDS of dollars potentially to be lost all for the lack of 3 60 cent washers, five mins of time, some threadlock, antisieze and two bucks worth of heater line.
Watch this space for good info.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 07-03-2010, 09:28 PM
SolReaver's Avatar
pics 1
THIS is a Turbocharger. To remove said part, you have to take off the intake and inter cooler tubing then unbolt the flange bolts and banjo bolts that hold the coolant and oil feed lines and disconnect the drain tube
The turbo on this model is a Garret T25. This one was spitting out oil from a leaking compressor seal. upon disassembly the piston ring seal on the exhaust side was found to be crushed and encrusted with coke. The exhaust pressure pushed into the turbo body and blew oil past the intake turbine seal. Once you remove the turbo, stuff some rags or paper towels in the openings to keep junk out.
I rebuilt this turbo. It is not as easy as it sounds, but it can be done. FIRST you have to scribe the intake and exhaust housings relative to the body or core prior to taking them off. Otherwise you will have a hec of a time trying to put it back together again. In case you forgot this critical step...look at these pictures and use them to orient the parts correctly.
Clean the unit and soak it...I mean REALLY soak it with some penetrating fluid for a bit before you begin to take it apart. I used "weasel piss" AKA PB Blaster, but any good stuff will work
well, enough of the great outdoors, the turbo goes into the vice and we work the 4 bolts that hold the turbine (exhaust ) housing to the core.
Old 07-06-2010, 07:24 PM
