Go Back   Pelican Parts Forums > European Car Forums > Saab Technical Forum
BC3 BC3 is offline
84 SAAB Turbo
I am working on a 84 SAAB Turbo / 8 valve. I need a fuel accumulator for the vehicle, because the current one leaks. I contacted Bosch and they said "They no longer make the part."
Currently, I am running the vehicle with the fuel accumulator hoses plugged.
Is there any problems doing this?
The car runs just fine; even better than before.
I do not smell gas.
I have no problems starting the vehicle when it is cold or hot.
Old 01-27-2011, 05:12 PM
jadewombat's Avatar
This car is CIS injected?
Should be able to use one off a VW as long as the fittings are the same. Pretty much all CIS systems run at the same inlet-side pressure from the pump.
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims)
Old 02-22-2011, 11:05 AM
