Failed emissions
2005 Porsche 996 c4s
46000 miles Took car for mot today after being sat for 6 months and failed emissions. Before i took her i filled it up with new fuel and gave it a few blasts up and down the road to get cats hot.Its only done 429 miles since last mot which it passed emissions ok. |
Failed for what exactly?
co too high
High CO levels normally result from over rich air fuel ratios, which could be anything from a dirty air filter to a sensor issue. If you have access to a Porsche specific scan tool like the Durametric system, check you fuel trims for over fueling.
Failed emissions
A few months ago i installed a low temperature thermostat would that make a difference.As they run hot because of emissions
Options are to … 1. Reprogram the CPU, Hard 2. Replace with stock thermostat to bring the engine operating temperature up, easier 3. Give the car a tune up while you are at it. Change the air filter, spark plugs, oil, and drive it aggressively for a few days then take it to test again.
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 11-03-2018 at 08:14 AM.. |
Then your experience is different from mine. I will believe it when you can dis-assemble the CPU code and show that the CPU is programmed to deal with 160F water temperature.
Yes JFP's experience is very different from yours, he knows every one of your cars far better than you do mechanicly speaking !
fuel emissions
What about where it as sat for a few months,IE would it need a good run
I have a low T in my 996 replaced along with WP a few months ago. Just passed CA SMOG Star Station testing with flying colors.
PCA, POC & SCCA long time Member |
If it sat for "a few months", particularly without fuel stabilizer in it, I would dump Techron in the tank and take if for a hard run before checking its fuel trims.
There is absolutely no reason a car with a 160F stat would do otherwise.
Winner!
Grappler
Are not the CATS more effective the hotter they get? I was always told to make sure the car is at least normal operating condition before testing.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
The reasons for getting the car up to "normal operating conditions", or steady state as it is known in the trade, is to allow everything to come to equilibrium. Good examples of why this is important are the misleading results you get when you check cam deviation values or engine sump vacuum levels on a car that is not steady state.
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 11-05-2018 at 12:53 PM.. |
