Torque on Water Pump Bolts
Is 7 ft-lbs really enough torque for the water pump bolts on my 996?
Spec is 7.5 so I go 8 with no problems
BigTim
A 1/4 inch drive, inch lbs torque wrench will be better suited to access the bolts and torque to
95 inch lbs. HTH Tim |
FWIW -
I just did the water pump (and thermostat, and timing belt, etc....) in my daughter’s Subaru last weekend. This guy has M6 screws holding the water pump on. I never even had the chance to feel one of them snug up before it pulled the original threads out of the block. So, yeah. Follow the torque spec. *In my case, I was able to reach with a drill / tap and insert a heli-coil. But I wasn’t happy about needing to do it. My guess is that the block casting was not so great in that one specific area. |
Torque is 10nm approx 7.5 lb/ft. No antisieze or other compound is required or recommended.
Cheers
Au contraire......we find fasteners associated with coolant, like the water pump or thermostat housing, can benefit from the use of anti seize compound. These fasteners suffer more from dissimilar metal and water corrosion that nearly any other in the engine, and being snapped off when being removed as the result. A little ant seize never hurts.
Do as you wish. These fasteners are not exposed to coolant when installed. Never seen one that would not come out easily on these engines, but perhaps it happens.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 Last edited by Jeff Alton; 11-11-2019 at 09:07 PM.. |
