wndsnd's Avatar
2006 Carrera S with 65000 Miles
I just purchased this car and the IMS has not been done. I have read everything and now I am seeing blurry.
At 65000 miles , from 0-10, o being none and 10 being it will explode, How would you rate my chances of having an IMS failure at this point.
Only reason I hesitate not just pulling the trigger and doing it is that for this early 997.1 I understand it requires and engine drop.
John
1973 914-6 Conversion
2.7, crank fired, twin plug.
2006 997.1 Carrera S Cabriolet
Old 02-27-2020, 03:27 PM
unindicted co-conspirator
looneybin's Avatar
It has the larger non-serviceable IMS
The motor case would have to be split to replace the IMS
They have a 1% failure rate from what I’ve read
Bigger issue is bore scoring
Old 02-27-2020, 05:04 PM
ims
I thought a 2006 model 997 could have a single row bearing that in the last of the 996
Old 02-28-2020, 02:46 AM
Negative. Some 2005 models may have had the replaceable bearing, but not the ‘06.
Drive the car. Change the oil every 3-4K and at least annually if less. Don’t worry. Be happy.
Old 02-28-2020, 03:09 AM
Uncertifiable!!!
Uwon's Avatar
Pull the oil seal on the IMS. I did at ~57k. I now have ~112k miles.
https://www.renntech.org/topic/43715-clutch-aos-water-pump-thermostat-diy-questions/
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 02-28-2020, 04:33 AM
ANY used car I buy gets a oil change A.S.A.P If it's a Porsche I also remove the oil pan to see what's in there if anything, & send a oil sample to LN engineering The IMSB experts.
Old 02-28-2020, 09:41 AM
wndsnd's Avatar
Good Advise BYprodriver
Old 02-28-2020, 02:49 PM
wndsnd's Avatar
This is my normal ride, this is a highly modified 2.7 twin plug, screamer. I am new to water cooled
Anyone know where I can get 997 Factory workshop manuals?
Old 02-28-2020, 02:55 PM
I assume you have collision insurance, Why not have a little internal engine collision insurance ? Nothing lasts for ever.
Old 02-29-2020, 02:05 PM
wndsnd's Avatar
I found all the manuals and Tech Bulletins. I think my insurance will be drop the engine and do a full service. At minimum I think I will do RMS, Serpentine belt, filters, plugs, and IMS. If case has to be split, I will service what I can without that drama, unless I find cylinder scoring.
Another fun project!
Old 02-29-2020, 02:52 PM
wndsnd's Avatar
Further research indicated that IMS Failure in 2006 models were slim to none on builds after 3/2005 - Mine was built 08/2006. I am not going to worry about it.
Old 03-13-2020, 09:37 AM
