Cylinder scoring
Hey, I need some help! After a track day oil was found over the engine and pooling under the intake. I had the motor inspected and found Oil pooling under intake. The shop Performed leak down and compression tests. 15% leakage on cylinder #2, scoring on bank one cylinder walls. What can I do short of scrapping the motor. Can I replace bank 1 cylinders and pistons? Do you have any suggestions? I want to track the car...?
Thanks for the discussion.
Peter
Old 08-12-2020, 10:53 AM
Peter
It would be highly unadvisable to try and replace just a couple of cylinder liners. You should do them all, and use the better LN versions to eliminate future issues.
Old 08-13-2020, 08:34 AM
Je suis une Canadien
ArcticOne's Avatar
I just finished reading Jake Raby's article on Cylinder Bore Scoring. It may be expensive, but fortunately it may not mean scrapping the engine.
John B
Nova Scotia CANADA
1999 996 Coupe (Felix)
1980 911SC (former keeper 2010-2015)
Old 08-29-2020, 04:23 PM
unindicted co-conspirator
looneybin's Avatar
The oil on the motor is likely the air/oil separator
Bore scoring won’t cause oil to get out of the motor except out of the tail pipe
Old 08-30-2020, 09:04 AM
I see it as a opportunity to upgrade the engine !
Old 09-08-2020, 11:29 AM
