There is no substitute..
Hi guys. First I have read a lot on people which have a NO DROP (which isn't my case) but I didn't find a lot of threads on people which the window doesn't drop enough.
Problem with the window, passenger side. What is working: (Door closed) - Lowering and raising the window completely. (Door open) - Raising the window, the window stop at the good place to close the door and then the window raise. Each time Not working: (Door closed) - Window drop about 1/8". I can hear the motor activating the drop but for a very short time. My door panel is also removed. I have about 1/4" dropped between the stoppers. When I lower the window and then I raise it, the window stop at the good position as mentioned in the What is working, and between the stoppers I have a good 2" maybe I didn't measured it but that's a lot compared to when I want to open the door. I tried to reset the window position holding the window button, I also tried to stretch the cable.. Why the window it stopping properly when raising it, but when I want to open the door, the drop is not correct..
--Matt I couldn't find the sports car of my dreams, so I built it myself Porsche 951 1988 - More than 305 RWHP & 350 RWTorque Last edited by FRZ951; 09-09-2020 at 06:51 PM.. |
If you can move the glass by hand at mid-position, your cable is stretched. You can try adding nylon ties at the green plastic bits to add tension. If not then it time for new regulator.
Never give up |
Actually I can move the glass by hand and drop it more more about 1 inch. But I wrote to my friend and he told me he replaced the whole regulator for a cheap brand.. for an unknown reason!
So from what I have read and what he said to me, everything seems to point to the regulator. I will just buy a brand new regulator this winter while the car sleeps and I will replace it. It should fix the problem! I will update this thread for sure once done.
--Matt I couldn't find the sports car of my dreams, so I built it myself Porsche 951 1988 - More than 305 RWHP & 350 RWTorque |
| Tags |
| door window drop |
