Tail is stuck in down position and warning light is on. Help please!
Counterclockwise?
Get out your checkbook!
Or go to the hardware store and buy 2 threaded rods and some nuts.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs Last edited by 911 Rod; 11-27-2020 at 05:15 AM.. |
Check to see if the spoiler is level in the down position, if not try to push the high side down to make it level so there is no resistance to movement.
Mine was stuck up on my 2001 and I was able to repair it quite easily with a member here who lives nearby. Good luck !
1985 911 Targa (sold) 2001 996 Twin Turbo (sold) 2001 996 C4 |
Pelican has the permanent solution: Rennkit's eRam Kit for the turbo. Several height options - maintains the turbo's wing deployment just like the factory intended. https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&make=POR&description=rennkit+eram
