996 Motor oil in bank 2 cylinders
I stopped on the road with heavy (HEAVY) smoke coming from the left exhaust pipe (bank 2). I've pulled the plugs on and all three sparkplugs were wet with oil. When I pulled the front plug, about a half cup of oil ran out. Where could all this oil be coming from?
Old 05-26-2021, 08:43 AM
If your oil level is overfilled or the AOS is not working, it can cause oil to be sucked into the intake and burned. I'd start with an oil dipstick check or the e-dipstick if you don't have an actual stick. The bar should NOT reach the top indicator. If it does, it also will not tell you how much OVER the top mark it is.
If it isn't that, then AOS is likely culprit. (That's Air -Oil Separator)
Tony G
10 Porsches come & gone!
1962 Morgan Plus 4
Old 05-26-2021, 10:19 AM
