2009 911 turbo, engine light, running rough
2009 911 turbo, manual 25k miles. Car started ran fine. Drove 2 blocks when check engine light came on an engine started to running rough like only on a few cylinders.
Was able to limp back to home??? Help! Thanks! |
Double posting gains you nothing.
Without codes, anything would be a guess………….
GT3 throttle body failure
This 997.1 911 turbo has an AWE 650 tune which uses a Porsche GT3 larger throttle body which is larger than a 997.1 turbo throttle body.
The electrics on this throttle body failed. I also changed plugs and coil packs. |
