Unknown sensor
This sensor or switch was dangling on its wire down on the passenger side of the engine on a 99 996. What is it and where does it go?
Old 09-07-2024, 01:06 PM
Porsche 911 Carrera S
OldSharp997's Avatar
It is probably number 4 temperature sensor in this picture. On my 2005 C2S, it controls the engine compartment fan.
Old 09-08-2024, 02:49 AM
Temp Sensor as mentioned above. If you've noticed your fan running overtime, its because this sensor is dangling out closer to exhaust heat.
Easy fix
Simon
Too many projects & a daily TDI:
-1966 Lotus Elan FHC (wasnt supposed to be a project)
-1969 Porsche 912-6 (not a project, yet)
-1986 325es with a 10:1 2.7L M20 (trying hard not to be a project)
Old 09-17-2024, 06:58 AM
If the grommet is still in the manifold take it out and put it on the sensor before you try to push it through. If you leave it on the manifold you will push the grommet through and it will land on the dark side of the moon.
Old 09-20-2024, 11:46 AM
