What are the best performance mods for a 951?
keeping in mind it will see some track time and be a daily driver.
Depends on what your budget is.
www.VitesseRacing.com would be a good place to start if you're looking for hp. Suspension upgrades may be more helpful for track use.
Steve '89 951 Alpine White/Blue, factory sport seats, Lindsey DP WG, MBC, Vitesse chips, 3 bar FPR, Evo diverter valve K&N filter, cat bypass, Koni Yellows |
MAF, chipset, wastegate (my favorite mod), cat bypass pipe, maybe an exhaust will get you about 65-75 more rwhp from stock. (Comes from freeing up the intake and the added boost most chipsets are programmed for.)
Throw a turbo and piggyback fuel controller on or get a vitesse kit like mentioned and the skys the limit. Injectors are needed once a new turbo is in and If you are going to do it all at once its way easier just to kit a Vitesse kit then buying everything separately. (These kits dont come with injectors or a wastegate though) Also once you do all this stuff a wideband is kind of needed - all depends on what you want.
1986 951 1995 M3 LTW 1995 Esprit S4s 2015 328d Last edited by Sam Grant; 11-14-2005 at 02:09 PM.. |
I thought the first step was a Chip, after that a test pipe 3"
and Digital AFM ..
David Alonso De La Vega Tapage Panama 944 Turbo |
A track/auto-x alignment is critical. The stock suspension is pretty soft too.
Sam, yours is sweet! How long have you had her now?
89 Porsche 944 Owner: AutoFreeFinders.com Online Auto Mall |
Thanks Dougster - been in the family since 1985. Dad got sick of it and let it sit - so Ive been driving it since 1997. He recently got the bug again and got a 993. So it all worked out in the end
1986 951 1995 M3 LTW 1995 Esprit S4s 2015 328d |
Yes, sounds like a happy story to me!
![]() What side of town are you on? I would love to see her sometime if you have time?
1. Clean up the car really well. Eliminate all leaks and ensure everything is tip-top from a a maintenance standpoint. 2. Suspension. Start simple with shocks and springs, and perhaps M030 sway bars. Places Like Paragon Products and Racer's Edge are great providers/advisors. And of course alignment. Follow the advice of folks with pedigree. 3. More safe bhp. For more than 10 years I have always advised people to buy Autothority, Weltmeister or Milledge chips sets. Everything else has MUCH less pedigree. Sure, some of it works... but other stuff will just blow tha engine up or cause problems-- pedigree counts. Remember Huntley Racing? 4. Join the PCA and learn about the pedigree of the people who make performance products for these cars. Once you understand the backgrounds and connections, you can pick the right pathways. Things like bigger turbos, exhausts, wastegates, test pipes, yada yada yada are all great ways to waste money if you are not careful. If you want to follow the safest, most cost-effective path, stick close to people who have raced the cars professionally.
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA |
