winter-hater club member
nynor's Avatar
n/a cam on a turbo
lately, i've read about this. has anyone done it? what about an 8 valve 928 cam?
"COOL PRIUS!" - Nobody Ever
Old 12-01-2005, 12:35 PM
Zero10's Avatar
I run a late N/A cam in my turbo. It had serious issues prior to this, and an unknown cam, but I can say for certain that the turbo spools up very quickly with the N/A cam
Buy my parts!
Old 12-01-2005, 01:58 PM
nynor's Avatar
interesting. any thoughts on why this would be?
Old 12-01-2005, 02:46 PM
Zero10's Avatar
1 degree more exhaust lift, 6 or 7 degrees more exhaust duration.
Intake is the same.
Buy my parts!
Old 12-02-2005, 08:07 AM
nynor's Avatar
so the exhaust exits the cylinders faster?
Old 12-02-2005, 09:00 AM
Ornery Bastard
Are there any other reprecussions from running a N/A cam in the Turbo?
Old 12-02-2005, 11:51 AM
Zero10's Avatar
People argue that the extra exhaust duration causes overlap, meaning lost boost. However, I have seen diagrams of the camshaft, and I don't believe there is any overlap. If there is, I sure am not having any boost problems as a result of it, nor any exhaust backfiring (which would be indicitive of this problem).
So, IMO there is no downside. And yes, the purpose is to help the exhaust leave the cylinder faster (higher exhaust velocity = quicker turbo spool) as well as force that little bit more exhaust gas out of the cylinders.
Buy my parts!
Old 12-05-2005, 10:28 AM
nynor's Avatar
oh boy! this is going to be fun!
Old 12-05-2005, 10:41 AM
Zero10's Avatar
Keep in mind this is not going to be a night-and-day difference. Perhaps not even enough to really be felt in the seat of your pants, but I do notice faster spool-up, which is always a big plus
Buy my parts!
Old 12-06-2005, 10:05 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I've heard you can use a 928 cam as well, but I believe the firing order would be different (wouldn't it?)
Black Cars Matter
Old 12-06-2005, 02:28 PM
Ornery Bastard
Depends. If the 928 V8 was a flat-crank V8 then the firing order shouldn't be different.
Old 12-06-2005, 06:01 PM
not-banned
A 928 cam will not work in a 944. Many have discussed doing the opposite (944 cam in the 928) on Rennlist:
http://forums.rennlist.com/rennforums/showthread.php?t=230371
http://forums.rennlist.com/rennforums/showthread.php?t=104624
Old 12-07-2005, 03:27 AM
Results improve with bigger turbo , I did this as well when I went to a k27/8 , I noticed a difference.
Stephen
Old 12-07-2005, 05:39 AM
Tapage's Avatar
Send a message via ICQ to Tapage Send a message via AIM to Tapage Send a message via Yahoo to Tapage
K27/8 is a bolt on upgrade .. direct replace for a K26/6 factory turbo, with no other modd needed in the computer or inyectors .. ?
David Alonso De La Vega Tapage
Panama
944 Turbo
Old 12-07-2005, 06:17 AM
Lots of other mods, just including my experience with this one.
Stephen
Old 12-08-2005, 09:38 AM
Tapage's Avatar
Good to know .. I'm not in this way right now ( not yet hahaha ) after my first step ( a chip ) figure some info about that ..
thanks ..
Panama
944 Turbo
Old 12-09-2005, 07:13 AM
Contact John @ Vitesse Racing when you are ready he has a great setup
Stephen
Old 12-11-2005, 11:12 AM
What Model Years?
From my research it appears the 944 turbo uses the same cam shaft as the early and mid 944 NA engines. What model year did the cam shaft change? The later cam is supposed to spool your turbo faster. Are there any aftermarket cams out there that are better for use in a street car?
'86 951, MAF, K27, 46 tial, 3" ext
'84 Audi Coupe
'87 Audi 5000 QT (QLCC chip)
'89 Merkur Scorpio 5 speed RIP
Old 12-12-2005, 09:41 AM
