MAF or MAP for a S2 w 951 turbo
Any recommendations (pro or con) on using either a MAF system or a MAP system on my 944 S2 with a 951 head & turbo system? I can go either way as the project is just being started. I have a complete, running hi miles S2 and a complete 944 turbo wreck from which to pull parts. Thanks in advance for your advice. Len
Vitesse appears to be the standard recommendation for a MAF kit. They have software for 2.8 and 3.0 liter engines as well. Lots of posts about them on Rennlist.
Stock 1988 951, TT aero wipers |
If I had to do it all over again...
If I had to do it all over again, I would use a MAP system. It appears much easier to package. No need to re-circulate the BOV into the measured air flow. The possibility of an intake leak causing a lean condition can not happen. Newer technology.
'86 951, MAF, K27, 46 tial, 3" ext '84 Audi Coupe '87 Audi 5000 QT (QLCC chip) '89 Merkur Scorpio 5 speed RIP |
Who makes a MAP conversion kit for this model? Len
Pretty much any stand-alone or Piggyback computer will accept a MAP sensor. I'm looking at running a MAP and an SMT6 or SMT7 on my supercharged S2 project.
1960 356 Super 90 - EFI'd 1989 190e 2.6 1991 964 |
Bar none MAP is best. As already said Motec, Haltech, Microtec, Link, AEM etc ALL use MAP. Its the best alternative out there, even more so for boosted cars. Link make a MAP specifically for our cars. Try www.NZEFI.com (for Link).
I definitely will go with a MAP system.
Does the Link system replace the Motronic ECU completely, or is it a piggyback? I would like to keep the S2 Motronics if possible. Thanks, Len
Ornery Bastard
Re: If I had to do it all over again...
![]() (I know, D-Jet is technically manifold _relative_ pressure, but I couldn't resist the joke.) I still think I'd prefer to recirculate the BOV even with a MAP system though, it can't hurt and might actually help keep the turbo spooled a little more.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Keeping the stock ECU will limit your functionality greatly. |
Re: Re: If I had to do it all over again...
Ornery Bastard
Re: Re: Re: If I had to do it all over again...
Yeah for example, the Tial BOV is 50mm.
