amunoz3's Avatar
1983 944 door help
is there some way to align the doors? when i bought my car the passenger door seems to close with some force needed and it doesnt seem to close tightly on the top so water leaks through the top when i wash the car .
Old 10-17-2006, 07:30 PM
SoCal Driver's Avatar
Last time I took a door off there were bolts going through the hinges and into the body. Could also have a bent door. Or a bent body.
Also the latch and pin adjust.
Does the door seal have a gap at the top rear?
Old 10-17-2006, 07:46 PM
amunoz3's Avatar
yes the top rear has a gap
Old 10-18-2006, 03:55 PM
I suggest replacing the seal with new. New ones have the gap at the bottom. Even think some of the new ones are continuous -- gap has been glued. The window part of these doors has a tendency to crack inside the door body just above the door handle. This will cause the top rear of the door to "bend out".
Old 10-18-2006, 04:23 PM
