Baza's Avatar
what coolent
I need to change my coolant and would like to know what coolant everybody uses and how you rate it?
Thanx BAZA
Always start with the cheapest option first
83 NA Guards Red ( Home at last)
2011 Triumph America
Old 10-18-2006, 12:47 AM
That Guy
Techno Duck's Avatar
You can use anything, just make sure its phosphate free and safe for aluminum engines. Coolant WILL destroy the head in particular if its not safe for aluminum.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-18-2006, 03:33 AM
I've heard that for those who don't have to worry about freezing temp's, that 100% water is more efficient than 50/50 water/coolant.
Something about water being more efficient at dispersing heat than a water/coolant combo.
Maybe the track junkies know more about this.
Jason
Jason Judd
Old 10-18-2006, 09:27 AM
bearone2's Avatar
Cool
50/50 is better. higher boiling point and freeze protection.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 10-18-2006, 09:34 AM
Razorback1980's Avatar
I'm not an antifreeze expert, but I do know that 50/50 is recommended for higher boiling point/freeze protection and corrosion prevention. But over 70/30 and boiling point/freeze protection and corrosion prevention actually decreases. As for water cooling better than the mix, I couldn't find information on that but it would be interesting to know for sure. Phosphate free, that's a requirement mostly for Europe more so than the US. Apparently the phosphate which is added for corrosion protection will cause deposits in European water and not so much so in the US....according to Prestone anyway. Since Porsche designs cars in Europe, it makes sense they would recommend phosphate free coolant. The part I would like to learn about but couldn't find anything about was which antifreeze was unsafe for aluminum engines and why. What ingredient is added that makes it unsafe for aluminum engines? Anyone know this?
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 10-18-2006, 10:44 AM
That Guy
I have seen heads come off 944's that have pitting in them because of the wrong coolant used. I am not sure how much that is attributed to not using a aluminum safe coolant or just not changing the coolant in the 20 years the car has been on the road.
One thing i know for sure of is to not mix the Dexcool stuff with regular green antifreeze. It causes whatever is in the cooling system to litreally turn into sludge.
Jon
Old 10-18-2006, 11:04 AM
Eldorado's Avatar
yep.. mixing pink with green = bad...
but pink (or orange?) was the only phosphate free antifreeze i could find at the hardware store up here... and there was green in it to begin with...
whatever is in there now is what my mechanic put in at the start of last winter season when i asked him to give it a coolant flush.
Kyle
Old 10-18-2006, 02:02 PM
Mike B's Avatar
I use the blue stuff sold at VW parts counters.
'86 951
'88 928S4 - the project
Old 10-18-2006, 04:03 PM
Baza's Avatar
Can anyone recomend a brand of coolant?
Old 10-18-2006, 04:06 PM
Dtchy's Avatar
I use Prestone...the orange coolant.
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 10-18-2006, 05:01 PM
That Guy
I use regular Prestone antifreeze. Its labeled under 'Extended Life' now. Its the regular green stuff in the yellow gallon jug. Im actually not sure if its phosphate free, but it does say safe for aluminum engines.
The orange stuff is Dexcool. Its my understanding that Dexcool is okay when the entire system is ONLY Dexcool and water. Mising Dexcool with regular antifreeze is where you will run into problems.
Ive been running it in both my 924S when i woned it and my 944 since ive bought it and never had problems, recently took the head off on my car and it looks fine.
Jon
Old 10-18-2006, 05:02 PM
I do too but last month when I checked the price VW wanted $28 for a jug in Toronto. It explains why I looked at this thread.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 10-18-2006, 05:16 PM
Zero10's Avatar
Zerex G05, Dexcool, Prestone yellow, Celsius universal, NAPA universal, VW G11
Take your pick from the above they are all fine.
Don't mix dexcool with any of the others and always flush your cooling system every 3-5 years.
Buy my parts!
Old 10-18-2006, 06:19 PM
Send a message via AIM to TheCooler
I got g12 for mine.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 10-19-2006, 04:47 AM
Prestone Extended Life
Tom
Old 10-19-2006, 08:06 AM
Mobil do an antifreeze recommended for porsche, phosphate free, also distilled water should be used.
944s2
Old 10-19-2006, 12:46 PM
surfdog4's Avatar
You don't want to use plain water, even if you are in no danger of freezing. Hot Water is very corrosive, and the Ethylene Glycol in regular antifreeze is there to make it less corrosive (and not freeze). It does reduce the ability of the water to conduct heat, so you dont want to go to very high coolant/water ratio.
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944 Maraschino Red Metallic (sold) )
Old 10-31-2006, 05:09 PM
Actually ph balanced water (distilled) is completely noncorrosive at any temperature which is why distilled water is recommended. It is the metal content within unpure water that makes corrosion. Corrosion occurs with two dissimilar metals have an electronic connection between them. The better the current path the more corrosion occurs. Salt water for example is more conductive to electricity than tap water, therefore more corrosion occurs in salt water than fresh water. That's the basis of cathodic protection. I used to work for the National Association of Corrosion Engineers based here in Houston and have read much more on the subject than I really cared to...but it is pretty interesting. Antifreeze reduces corrosion by increasing the resistance to electrical current. The negative side to reducing electrical current is that it takes away the heat transfer properties as well. So if you do use pure water, make sure it is distilled.
Tom
Old 10-31-2006, 08:36 PM
TSNAPCRACKLEPOP's Avatar
do you guys put the "pills" in the engine? cadillac uses them in some of their engines, its some organic mix pill to reduce corrosion, available from the dealer parts counter.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 11-01-2006, 09:14 AM
I don't use them, I just use antifreeze which does almost as good a job. If you keep your coolant changed and just use antifreeze, the engines will last a very very long time without suffering from corrosion.
Tom
Old 11-01-2006, 10:40 AM
