Failed Trailing Arm
Has anyone ever heard of something like this? This is a rear trailing arm from a race car. I've been running solid bushings and mounts on the rear suspension for two seasons. Problem or coincidence? The front control arms failures are well documented, but I've never heard of this before. Another important inspection item!
Old 10-23-2006, 04:26 AM
Burn the fire.
Brando's Avatar
Was the car previously damaged in a collision?
I've never seen that of failure on a 944. I've heard that the best way to tell if your trailing arms or a-arms have cracks is to get them up to about 350º and the cracks start to show. Or x-ray inspection. But who has the money for that?
"Drive it like you stole it."
Old 10-23-2006, 07:39 AM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
what kind of suspension are you running? Coil overs? or ultra thick torsion bars or both? My only thoughts are that it was a bum casting or the solid bushing is binding/forcing something out of wack to cause an eventual failure. first i've seen.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 10-23-2006, 07:41 AM
Feelin' Solexy
Tishabet's Avatar
Dang!!!!
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 10-23-2006, 07:58 AM
Altogether in the rear: spherical trailing arm bushings, solid torsion tube carrier bushings, solid torsion tube block mounts, 525 lb coilovers, no torsion bars, Leda shocks, -2.5 degrees camber, 15x8" Fuchs, Tarret sway bar.
Old 10-24-2006, 03:35 PM
Dtchy's Avatar
Looking at the crack, it doesn't look like a fatigue failure that happened over a long period of time.
It looks like the car got a serious hit and at that moment the thing broke in half. Did you get in a collision on the track?
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 10-24-2006, 04:33 PM
Not to cause the control arm to break, but after the break, yes. I only know from the corner worker's report... The arm broke on turn-in. The break and impact with another car happened so fast that I had no time to appreciate that I lost one corner of the car.
Old 10-25-2006, 04:08 PM
