Throttle Dive Compensation
I had a 968 with a lighten flywheel. (Took the 34Lbs down to about 15Lbs) Along with the good Crisp Response came the bad Throttle off dive. Now I'm gonna have a lighten Crank as well.
SO.. How do I compensate from the diving RPM's when the Throttle's off for shifting and such??
The Honda's uses something called a Dash-pod which is a vacuum controlled Throttle body bladed controller. This slows the closing but does not effect the opening.
Anyone have anything they've heard or done to help.
Old 10-30-2006, 10:30 AM
bumperoo
Old 10-31-2006, 12:16 PM
Burn the fire.
Brando's Avatar
Use the gas pedal? Works good for deceleration as well..
"Drive it like you stole it."
Old 10-31-2006, 01:05 PM
Shift faster?
My cars for sale, due to move
1986 944 turbo - For sale.
1987 944 N/A - For sale.
Old 10-31-2006, 01:35 PM
