manually opening hood
i was helping my friend replace his alternator, and battery. The hood and trunk managed to get closed, and since both are electric, im wondering how i can get to the manual release or to the fuse that powers the solenoids so i can manually pop the lids. i can just hook power to the lighter outlet since the alternator lead is resting on the block and according to the crappy wiring diagram i have there is no main fuse link, so i cant just jump the car and sacrifice the fuse. My diagram also does not include a schematic that has either solenoid or their switches.
based on the disassembly guide there is a manual release somewhere, possibly in the drivers fender well area?? if its under the tail light how do you remove it with the trunk closed
if anyone has a schematic with the hood/trunk circuits that would be great
65' 912 WRX RS
Old 01-29-2007, 01:14 PM
There IS a manual release in the front, supposedly accesed through the right front fender well as I have never tried.....supposedly visible as well when headlight assy. is removed.
If there are no dogs in Heaven, then when I die I want to go where they went.
-Will Rogers
1999 996 FOR SALEhttp://forums.pelicanparts.com/showpost.php?p=3788325&postcount=1
Old 01-30-2007, 09:20 AM
got it figured out, the front release is in front of the passenger wheel and the rear is behind the drivers wheel
65' 912 WRX RS
Old 01-30-2007, 09:29 AM
Mookster's Avatar
Where in front of the front passenger wheel is the manual hood release? Up high, down low? Is there a lever...
Your help is appreciated.
If it has a skirt or tires, it WILL cost you money!
Old 08-24-2008, 06:06 PM
mine is in the passenger radiator area
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 08-25-2008, 03:07 AM
