Dropping 996 Engine
I'm replacing my 3.4 engine and have taken out all of the stuff underneath the engine. Seems a lot of room to be able to drop without the trans. Any of you guys dropped this engine only without the tranny? I know the conventional way is to remove with the trans, but would save a lot of time if the motor can be dropped by itself. Thanks.
Old 04-13-2008, 07:32 AM
914helo's Avatar
Sure, you can drop just the engine. You'll need to disconnect the CV joints and as you lower the engine you can reach the upper transmission to engine bolts. Be careful not to bend the transmission input shaft. I have the rear wheels removed and after diconnecting everything actually lower the car and place the engine on my ATV jack. In a crunch on my 914 I've used a furniture dolly. Then raise the car without the engine. Just take your time and make sure everything's disconnected.
Kent
'73 914 - Suby 3.3L conversion
'99 996 - For sale ($22K)
Old 04-13-2008, 04:07 PM
Thanks for the input. Did you have a problem aligning the trans input shaft to the clutch upon reassembly? Im asssuming the CV joints have to be removed so the trans can be lower further? Thanks.
Old 04-13-2008, 08:19 PM
914helo's Avatar
Yes, I disconnect the CV joints so that the trans can be lowered some for removal/installation. The trickiest part of the reassembly is the initial lineup. Use the engine case bolt and guide pins to line it up, then lift the engine up. Sounds easier than it is, but no too bad.
Kent
Old 04-14-2008, 06:11 AM
