glenndeweirdt's Avatar
loose anti-roll bar?
I have a "clunking" sound from the front end of my '99 996 with 52K miles on braking. This nly occurs after I have backed the car and braked. When I go forward and brake I hear the clunk. It only happens the first time I brake then dissapears.
I think it is a loose anti-roll bar. When I put the car on my home lift the bar has a bit of play (enough to make a slight rattling sound but not that loose). Is this normal. The bolts are tight but the bushing connecting the anti-roll bar to the slender vertical control arm seems worn.
Any thoughts? Is this a problem or a minor annoyance?
PCA National, BMW Club, SCCA HPDE Instructor. MSF Level 2
'23 BMW 540 iX (wife's driver)
'14 Cayenne Diesel DD and tow vehicle
'16 GT4
'22 911 Date night vehicle
Old 08-25-2008, 01:21 PM
It could also be the brake pads shifting back and forth when you brake in reverse and then forward. My turbo brakes used to do that with Axxis pads.
Old 09-23-2008, 04:28 PM
BT911's Avatar
you shouldn't have any play in the sway bar links. double check the lower nuts and make sure those are tight
Old 09-23-2008, 04:51 PM
If your sway bar was loose it would make noise when driving over bumps etc.
Old 10-10-2008, 09:51 PM
On further investigation it seems like the brake pads shifiting slightly. Is this a problem?
'16 GT4
Old 10-11-2008, 05:45 AM
It is not a problem. I drove my early 911 fitted with turbo brakes for 17 years with this happening. Sometimes it would change/go away depending which brake pads I was using. You are better of with them a little loose rather then tight. If they were tight it could cause brake drag and over heating, rotor warping/cracking, grease boiling out of the bearings etc.. Double check the caliper mounting bolts to make sure they are tight.
Old 10-11-2008, 05:50 PM
