Any changes in 996 engine, 1999 vs later years?
Just bought a 99 - 996 which had engine replaced (2006) courtesy of Porsche. Would like to know if a 2006 engine (or later years 996) might have resulted in any improvements in reliability, hp, etc.
Also, does anyone know where i can check block casting numbers to find out what year this "new" engine might actually be? Thanks. |
I think the remanufacturered motors have a different ID number/sequence (at least I recall that from a Boxster engine discussion.) HP change? no. Reliability? perhaps.
Your replacement engine is almost surly a 3.4l just like the original was. In 2002 the 996 got a face lift and a bump in displacement to 3.6l producing 320hp (up from 300 for the 3.4)
The biggest difference would be the updated intermediate shaft with the larger single row bearing. I've seen this update/upgrade even on replacement engines for 2.5 Boxsters. Otherwise, no notable changes.
Don Weaver-EBS Racing [email protected] 2006 Cayman S '86 944T '00 Boxster with EBS Racing 3.4 liter engine |
Thanks. I had been reading about aftermarket crankshaft bearing improvements, and was wondering if they ever made that correction on the 3.4. Now, when you say "intermediate shaft" you are referring to a bearing midway on the crankshaft, right (i.e., not one of the end bearings)?
1974 914 2.0 1980 911 SC 2002 996 Cabrio 2000 Silverado 2011 Golf |
Thanks for the info. I think it's time I updated my knowledge about the P water-cooled engine and looked at an exploded diagram of the internals. Seems like an extra shaft in the process would increase the friction, and therefore rob energy -- but I'm sure a couple of engineers at Porsche musta thought of that beforehand.
