Battery Disconnection Questions
Hi,
I have a 2004 996TT.
Its in storage for winter and wont be used for a couple of months, if I disconnect the battery and close the bonnet will I be able to open it again by using the power lead connection in the drivers (UK car) footwell that I use to open the bonnet when the battery is flat ?
Thanks.
Old 01-07-2010, 02:25 AM
You should be able to.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 01-07-2010, 03:23 AM
Rrrockhound's Avatar
Why not just leave the bonnet ajar?
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 01-07-2010, 05:37 PM
Its stored in a communal garage.
Anyone know for sure, I dont what to try it and then find out there is no way to open the bonnet.
Old 01-08-2010, 04:51 AM
Well, it ought to work since that's what it's intended for, but if push comes to shove, there should also be an emergency release cable under the front bumper.
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 01-08-2010, 04:57 PM
thanks will give it a go !
Old 01-09-2010, 02:33 AM
Send a message via AIM to JHoffman Send a message via Skype™ to JHoffman
If it does not work and you left the battery cover off what you can do is use a long screw driver. Connect the + end of the jumper box to the screwdriver and the - to a ground. Touch the screwdriver to the + post and pull the switch.
Old 01-15-2010, 02:39 PM
