Guest
Posts: n/a
How do I check or reset my convertible to 996 2001 it will not go down the light just flashes but nothing happens
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Convertible Top Repair - 986 / 987 |
Author of "101 Projects"
The roof mechanism for the 996 is controlled by a central computer. In order to figure out what is wrong, you need to hook it up to the Durametric code reader software (or the factory PST-2 tool), and read out the codes for the roof repair. The computer should then tell you what is wrong, and point you on your way to fixing it. The Boxster roof is basically a manual system that doesn't have a complex computer controlling it (just a small control module plugged into the area above the fuse box).
- Wayne
Make sure the pk brake is set.
Check the fluid level in the resevoir behind the rear bulkhead cover.
