aoua's Avatar
Instrument cluster FUSE continues to blow
I just interchanged the control unit for the heater controls (straight forward no issues disconnected one and plugged the other in), noticed my dash went black after i turned on the ignition. Changed instrument cluster fuse, continuously blows IMMEDIATELY when I change it.
Any ideas?
2003 C4S
Any help would be great
Andreas
1971 911T TARGA
http://www.pelicanparts.com/gallery/aoua/
Old 05-08-2011, 06:15 PM
Just did the same thing. I think its because my heater control unit is sourced from the US and mine is a UK car. The part numbers were out by the last number. Mine ended in 9. I think I need the one ending 3?? Cant remember.
Mine was just a half malfunctioning screen so put the old one back. Just the cluster not working so glad to hear yours was just a fuse and mine is likely to go back on when I switch the fuse.
Which part number did you put in? I now have a spare US part, to go back on ebay shortly.
Old 06-07-2011, 03:36 PM
the last digit on the part numbers is the revision number, so the 09 is a newer revision then the 03
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 06-08-2011, 04:57 AM
Ah ok. Thanks for the explanation.
When I put the 03 in it was reading out degrees F not C for the temperatures. I thought this to be a sign that it was the wrong part, along with the blown fuse.
So can the deg f be switched to C? Or is this going to cause a conflict? I didn't go as far as to check the PCM to see if it had switched to f there. Maybe it can be switched back via PCM?
Perhaps if I fit it with the fuse out it will not blow it again..
Might hold on to the part if I can make it centigrade and its ok to use...
Be good to hear your thoughts on that.
Old 06-09-2011, 12:42 PM
I know this is an old thread but did you ever resolve this?
Doug
Old 07-03-2023, 05:30 PM
