Is the battery vent really necessary?
My Wal Mart battery (group 49) just died and it had leaked battery acid through the vent hose and around the battery itself.
So the fun now begins trying to find a replacement battery. Walmart no longer carries the group size 49 and my local store was out of stock on the 94R version. Now, every other "94R" battery I have found does not feature a vented cap system. Should I really be concerned about retaining this feature? Is there a red Optima unit now that will fit the stock tray? Thanks, Eric |
Yes the vented battery is necessary for proper ventelation for breathing into the air cabin system. I know because my mechanic told me this when I replaced my battery about 3 weeks ago.
If you have a vented battery yes.
After fighting rust in the battery boxes on my 1970S and 1972T. I would buy an AGM, GEL or a sealed no maintenance battery before I would replace with a vented battery. Your car can use a group 48, 49, 94R It has different mounting holes in the plate for each. Last replacement for my 2003 996 I went to an endurance Braille GRP 48 AGM. They also have GRP 49 both are expensive and straight bolt in replacements. I have been using AGM batteries for ~15 years. Currently in my BMW R1100RT and 1972 track car. The bike battery is still going strong after 9 years and the car batteries are still good after 12 years. YMMV Braille Battery USA      Lighter • Stronger • Faster - B7548 Costco, Sears, Interstate, Porsche also have replacement flooded, lead acid, vented batteries for ~$79-$150 if that is the way you want to go. Make sure to clean up the residue from the spill with baking soda/powder solution to neutralize the acid before it eats into the bulkhead under the battery tray.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 Last edited by FPB111; 06-27-2011 at 09:00 AM.. |
That's what I was thinking, why not replace it with a 100% "maintenance free" battery and not deal with the potential issue of corrosion caused by these leaking batteries. Just a note, I was unable to power up the car through the power stud inside the fuse box in order to open the trunk. I ended up using the cigarette lighter method. Not sure why... |
Thanks for the link!
Just a note, I was unable to power up the car through the power stud inside the fuse box in order to open the trunk. I ended up using the cigarette lighter method. Is this a bad sign? Reply With Quote |
In the shop at Pelican
Yes, in a pinch, you can use the lighter to charge the battery. The battery vent is there for a reason. Use it.
Jared,
What if it is a sealed battery? Drill a hole to stiick the vent into? What did you clamp the ground to?
If it's a sealed battery, it's not the correct battery. Or at least, thats my official answer. If there's no vent in the battery, don't worry about it.
Looking around for battery info, I found this old post. I think a gel battery does not have a provision for a vent, so no vent. Some sealed batteries have not been drilled for the vent but have a boss there for one. Don't do this yourself, buy a battery with the hookup. And use it.
Comment below and don't forget to like and subscribe. |
If you buy a replacement battery with the vent, then use the tube. If you buy a maintenance free battery without a vent (which won't harm anything), then just tie the unneeded vent tube back out of the way. Easy breezy.
1999 996 C2 sold - bought back - sold for more 1997 Boxster BSR POC/PCA #254 1978 911 SC Daily Driver Licensed DE/TT Instructor |
Braille AGMs have gotten very $$$ try:
Duralasts AGM Platinum/Battery Price: $179.99 AutoZone, we refund the core charge to you. $15.00 Part Number: H7-AGM Also Sears Diehard AGMG GP48 Item #22850748 for $174.99.
WalMart currently has the proper group 49 battery. About $100. I just changed mine.
The vent is configurable and my 996 vent system plugged right in. IIR, the warranty is 3 years which is about as long as batteries last in Florida's heat.
'09 Cayman '01 996 Carrera, RIP '79 911SC Targa sold to a collector in Germany! '87 944S sold! '86 944 sold! '74 914 2.0 sold but not forgotten - my favorite |
