Weekend Mechanic
IMS Bearing Upgrade Question
There are three chain tensioners on the 996 engine (Main Tensioner, 1-3 Cylinder Bank, 4-6 Cylinder Bank). Wayne's article only mentions loosening/removing the main tensioner and the 1-3 tensioner. Is the 4-6 tensioner (located under the AC compressor) not a concern?
86 911 Carrera Targa
When I did my IMSR, I loosened all 3, but I have read many times that the 4-6 is not necessary to loosen.
Weekend Mechanic
Thanks for the answer Rick. Did you remove the tensioners completely or did you just loosen them a bit? Did you use the set screws to secure the IMS sprocket or did you just lock the cams? Or both?
I just loosened IMS, 1-3, and 4-6. I just made sure that I didn't move the cams in the process and confirmed they didn't jump during the procedure.
pin the crank at TDC before you start and it should be OK. Fancy tool can be replaced by 5/16 metal rod
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 Last edited by FPB111; 07-02-2011 at 06:28 PM.. |
