cabrio rear roll bar cover removal need help
I have an 01 996 cab. The rear trim that covers the pop-up roll bars that runs the full width of the car, directly above and behind the rear seat backs, is loose on the drivers side. I need to remove it to inspect/repair/replace.
I have attempted to remove the rear panel behind the rear seat backs - easier said than done. This panel is held in place with 2 screws (easy) AND the front edge of the pop up cover (bummer). It seems that I may need to remove the rear seat backs in order to remove the panel. I don't really want to go removing too much interior if it is not required.
Any one had experience in removing the pop-up cover or rear panel?
Thx
Old 03-13-2012, 05:32 AM
3. Pry off the top oblong covers directly over the roll bars. Work from the rearward side of the covers not the front side. There are three spring clips, left , center and right so if you work with a wide bladed screw driver start at one side, then the middle, then the other side and the covers will pop off.
From this thread
http://forums.pelicanparts.com/porsche-996-997-forum/667592-997-hard-top-fit-996-a.html
Old 03-27-2012, 09:45 AM
I am looking to remove the whole cover that runs the whole width of the car. It looks like I need to remove the rear seat backs, then the seat back mount in the center, then the rear vertical panel - and that should give me access to two screws that hold the long cover in place. Does that sound like the right procedure?
J
Old 03-27-2012, 05:46 PM
If you go to this thread and look at the pics and read the text you might see a way to get the cover off... "The entire cover will lift off now and exposing the roll bars and the carrier frame rails where the mounts bolt in."
Maybe yours is different?
How to retrofit a 996 hardtop to fit a 997 - Rennlist Discussion Forums
Old 03-29-2012, 08:46 PM
giant help, great link, thanks a bunch!
Old 03-30-2012, 11:20 AM
