Blacked out Fabspeed Intake
I have OCD when it comes to modifications and was not happy with the red intake that comes with most kits. I found the black intake on ebay and here it is.
How does this make power?
I'm sure there are plenty of debates on whether this makes power or not in the forums. It definitely makes more noise which I like by eliminating the air flow to the muffler in the airbox. There discussions on how to accomplish that for almost free. Being able to remove the muffler in the airbox makes sense to me as does smoothing out the intake tube.
From Fabspeed's website: 25% better Airflow = More Power Any 996 with JUST the COLD AIR performance enhancement kit installed will make any 996 with STOCK mufflers sound as if you have added a mild performance exhaust. Perfect for any 996 owner that wants his car to sound slightly more aggressive than stock. Finest true hi-performance COLD-AIR intake system available. Adds 1.5 Liters cold air by eliminating muffler in airbox. This allows engine to draw cold air across entire topside of air box (left and right rather than just from the right). .42 seconds faster acceleration 3000-6000 RPM. 4 ply silicone tube - better flow from airbox to throttle body. No C.E.L. light as you retain the factory MAF plastic screen/grill to straighten out airflow. Last edited by scats; 04-23-2012 at 01:18 PM.. |
Maybe I'm not seeing it. It looks like a stock intake. The fab speed intake is a cone filter with a heat block.
1985 Euro Red Carrera Coupe."SOLD",1985 White Targa Carrera. "SOLD",1977 Yellow 930. "SOLD",1991 Black 964 C4. "SOLD",2002 Silver 996 C4 Cab "SOLD", 2001 Polar Silver 996 twin Turbo |
Yes. Sorry, I have a different fabspeed set up for my 996.
Couldn't you just block the smaller tube to the left with a plug inside the box?
Seems a whole lot less expensive than a new FabSpeed intake. Last edited by DaveBerry; 04-27-2012 at 04:07 AM.. |
You can cap it and leave the internal muffler in the air box or you can use some plumbing parts to cap the hole left behind. But the extra $100 to do it right and make it look professional was the right choice for me.
OK, does the FabSpeed intake replace the OEM paper filter with a cone K&N type of oiled filter? Is the OEM AirBox basically left alone, just plugged? I am curious about this. I would like to have some more growl in my 911, mine just purrs.
