99 911 engine swap
I am swapping out the engine in my 99 911 C4, I have a used engine with 71k coming in the end of this week. My question is I know I should check the IMS bearing and the RMS, and probably do the clutch while it's apart, but is there anything else recommended while it out and apart I should be looking for or doing ? Also my car is a 6 speed and the engine is coming from a tiptronic, are all the vacuum lines and everything going to be the same ?
Glad you found an engine for your car. You might want to have a look at the hose that goes to the slave cylinder. If it is moist or has any cracks it should be replaced. They are a bear to get while everything is in the car and while it's out you could just replace it. I think they are under 30 bucks. I don't know about the vacuum lines but the water pump and AOS should be replaced if you do not have records of when they were done.
The Cam chain tensioner wear pads should be replaced with the updated material parts that wear much better & cost $40 since at 70K+ miles they look like this: this:
Good call Bill! That is a chronic issue with the early motors and when they do fail it's really bad. In fact, all of the chain rails are likely looking pretty sad...
Don Weaver-EBS Racing [email protected] 2006 Cayman S '86 944T '00 Boxster with EBS Racing 3.4 liter engine |
Thanks for your input guys, made the appt today to have the following done, the ims bearing, rms and the cam chain tensioners, i am going to do the water pump and the aos myself, doesn't look that hard to do....
So the engine hasn't been delivered just yet, trucking delays of some sorts, But over the weekend someone brought up and interesting point maybe someone could clarify.
my car is a 99 C4 6 speed, the engine I am getting is from a 99 C2 with tiptronic, it's complete, does anybody know if the wiring harness on the engine the same ? or should I swap that out ? couple of people have said yeah it's the same, and a 1 person said no it's not... Better to be safe than sorry and change it out ? |
Not sure on wiring harness -- but your connection near the thermostat is different between
a tip and stick m
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
You are adapting the "new" engine to fit your car so drop your engine with harness & put it side by side with new engine & transfer your harness to "new" engine along with any other parts missing from "new" engine. There may be wires etc you don't need on the Tip harness.
