Battery options
I have a 99 Carrera 6sp Coupe. I am the second owner.
What I have been dealing with for over two years is a good battery (checked everything including a hydrometer) that sometimes takes three or four tries to fire up the engine. I have never been stranded. The dash gauge while running shows 14 Volts. I am going to eventually put another battery in. Sometimes it is a little embarrasing leaving a friends' house even tho it will evertually start. What happens is it will crank for a short period and then quit. I have to release the clutch and try again. It is worse in real hot (90 degrees on up at running temp, 200 degrees f). I am thinking it just might be normal because I live in a hot climate. I don't know. What battery fires up the engine every time? I will get one. Thanks. |
Had to upgrade my battery after 2.5 years on Group 48 Replacement Battery - Rennlist Discussion Forums
I prefer AGM (Absorbed Glass Mat) Gel type batteries I replaced an Interstate MTP-H7 With a Braille endurance series 7548 AGM battery - direct replacement. Braille AGM B7548 battery group 48 BCI Group: [?]Group 48 Length:10.9" (277mm) Width:6.8" (173mm) Height (without posts):7.5" (191mm) http://www.braillebattery.com/ http://www.braillebattery.com/index.php/braille/product_series/endurance_series Battery sizes that fit 996 (group 49 will probably need a nut under the last, unthreaded, hole in the tray) Group Interstate number Dimensions L x W x H Posts 48 MTP-H6 10-15/16 x 6-7/8 x 7-1/5 Top 94R MTP-H7 12-3/8 x 6-7/8 x 7-1/5 Top 49 MTP-H8 13-15/16 x 6-7/8 x 7-1/5 Top
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 Last edited by FPB111; 10-24-2012 at 11:42 AM.. |
I'll get one.
Thanks. |
Hurdiguirdiman
Try a Bosche at just over $100 from Pep Boys. If that doesnt do it then it's certainly not a battery fault. You have to look further. Or even better, take your battery to be tested at Pep Boys. If they says it's good then you have to look further into your problem.
I took the battery in and it basically will not charge past 52%.
That was why it would barely turn the flywheel. Anyway, I put in a new battery and all is well. Batteries can be expensive. Some in the $300.00 range. I shopped and got a 48 for $135.00. Much better now. Alternator is putting out 14 volts. Battery static voltage is 12.7. Thanks for the help. |
