brock911's Avatar
ABS failure and PSM failure
Took my 02 turbo out for a drive today, finally having some decent weather. Pulled on to the highway and opened it up a bit, almost immediately after hitting a little speed both the ABS and PSM failure lights come on?
I pulled over and shut the car down, waited a minute and started it back up... no lights?
Anybody else have this experience or care to share what may have caused it?
Thanks,
Mike
Old 04-14-2013, 11:57 AM
ABS and PSM MIL lights are a common feature of low voltage excursions on the charging system.
Old 04-14-2013, 01:02 PM
Stranger on the Internet
patkeefe's Avatar
My Boxster did that also. Bad brake light switch.
Patrick E. Keefe
78 SC
Old 04-14-2013, 05:04 PM
brock911's Avatar
Thanks guys, I did a bit more research and have identified a few possible culprits... MAF sensor, brake switch and maybe voltage regulator and or alternator.
I will try and identify when it happens if it happens again which I suspect it will. The volt gauge is not acting funny so I will check my brake light to see if they're working and take it from there.
Stay well guys,
Mike
Old 04-14-2013, 05:51 PM
