Sunroof question
I have a 2000 996 C4. It has about 130K miles. About 2 months ago, the motor from the sunroof began to slip and so I looked at the manual and decided that I could do this repair myself
![]() . I know, big mistake . However, removing the old motor I found the white plastic disk was missing some of the teeth. I purchase a used one off Ebay, and installed it. The motor is strong, but the sunroof is opening and closing only partially. I call the party that I purchase motor from and they tell me they checked it and it worked fine. Not wanting more problems, I am at Festival of Speed in Fontana and am talking with a guy with a race converted 996. I ask him if he has any parts that were stripped from the race car and he tells me he has the sunroof motor which was working excellent. He sells me the motor and I install it and now the motor is strong, but it won't close all the way. Is there a part that I am missing which tells the motor what to do Any advice in this problem is much appreciated.
Larry ![]() "We are the youth you crummy bastards, we are the youth" Harry the Hipster ![]() 1974 911s 2.7L Olympic White w/Red Leather interior 1991 928 S-4Guards Red SOLD 2000 911 996 C4 |
Hi Larry
There is something in the factory manual body exterior section about resetting the limits for the sensors on the sunroof. It's similar to doing the windows after you disconnect the battery. From a closed position hold the lift button in for a full cycle of opening and closing the roof. maybe someone posted the routine on RennTech.org I'll see if I can find the steps later this week. |
Thank you, I appreciate the advice. I will give it a try and let you know if it worked
