Best Oil/Additives for 997
I just bought a 2005 Carrera 997 with 3.8L engine. It has 67,000 miles and runs great. I have the service records and it has always run Mobil 1 full synthetic. I want to use the "best oil"and change it every 3000 miles or so. What is the best oil to run in these engines? How about additives?
Old 08-08-2013, 03:26 PM
The "best oil additive" is rather simple: None. If you run good oil, you don't need additives. As for which oil; that is a subject that starts wars and ends friendships............
Old 08-08-2013, 05:09 PM
As usual search is your friend.
Old 08-08-2013, 05:58 PM
Uncertifiable!!!
Uwon's Avatar
Oils: What motor oil should I use? Which oil is best for my Porsche or aircooled engine?
Then scroll down to the section titled
What oil should I use in my newer Porsche requiring a "Porsche approved" oil, like the M96 or later Porsche engine
Straight from the master Charles Navarro..... And you won't loose any friends.
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 08-09-2013, 02:14 AM
To All, thanks for the advice. I'll take it from here.
Old 08-09-2013, 04:17 AM
Luxter's Avatar
And here:
http://forums.pelicanparts.com/porsche-911-technical-forum/367300-ultimate-motor-oil-thread-why-we-hate-cj4-sm-oils.html
And here:
http://www.911uk.com/viewtopic.php?t=85575
And most importantly here (directly related to your (and mine) C2S):
http://www.hartech.org/docs/buyers%20guide%20web%20format%20Jan%202012%20part% 205.pdf
Happy reading!
Will try to add some more later.
L
Old 08-09-2013, 11:56 AM
996TWINS's Avatar
IMHO changing the oil every 3000 miles (unless it has been 12 months prior) is a waste of time, money, oil, etc.
I track my car, and ran it with ~250 miles of tracking @ 125 to 145MPH, most of it at 90 to 100°+, and ~750 street miles . Sent in my oil samples (engine, trans, and differential) to Blackstone for an analysis. The results basically said that running all the fluids twice as long before the next oil/filter change would be fine.
Contact Blackstone for a kit, send in your oil samples and let the results guide you to what you think is best.
+1. Stay away from additives and only use approved oil.
Old 08-09-2013, 02:23 PM
