Quiz: Whats wrong in this picture?? M96 engine
What do you see wrong in this photo ??
![]() Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
NYC
Where are the bolts that hold the extraction pump in place? Is that sealant I see down the side of the case?I have done a few of these that were installed backwards.
I removed the bolts & yes way to much sealant on the cam covers. This one isn't installed backwards, its installed sideways. Both bank1 & 2 were installed like this. This photo is cyl 4-6. the 4-6 numbers should point toward the case or in this case the flat machined area.Thank goodness for them the car wouldn't move or it would have been bang in a few miles. There is 1 more problem here & that is the true comedy of errors.
NYC
Yes I have seen that. 1-3 on a boxster is on the right side and is on the left side on a 996. The engine will run with the pumps reversed but will make a a lot of noise that comes and goes away.[The pumps are identical and people install them incorrectly. In your photo I can see the 1-3 numbers are on the seam where the cam covers bolt on. Somebody made a mistake.
NYC
You said there is another mistake does it have something to do with the numbers on the case? Does that type of pump belong on that case? I need a larger photo.
Pumps are correct, look at the color of the oil.
Looks like way too much non-Porsche approved sealant & strange colored oil too.
It doesn't appear that the case was sealed properly and H2O mixed with the oil.
94 turbo 3.6 74 carrera RS race car 05 denali XL "We are here to laugh at the odds and live our lives so well that Death will tremble to take us." Charles Bukowski |
NYC
I agree with all of you on the color of the oil however when Howard said another problem and comedy of errors I was looking for something else in that photo.. Somebody probably added another fluid into the engine such as coolant.
This is the first time I have seen these pumps installed sideway. Usually they're reversed.
You are correct, They put the coolant in the wrong hole & oil in the other wrong hole. Thought I had a intermixer in the beginning,but not enough chocolate milkshake in the cooling system for that. Flushed cooling system 6 times & oil twice. All is good so far. I will drive this one for a few more days.
NYC
I guess you corrected all the problems and the engine is running properly. Did you get the vehicle at a good price?
I didn't buy it. I repaired it for the owner that got screwed by the previous shop.
