ODB code P0348
OBD code P0348 the info from my basic reader displays "camshaft position sensor A - Bank 2 Circuit high input"
Is a 2003 C4S 75k miles. I've a Durametric on order. Any thoughts ?
"And there's no cure like travel to help you unravel the worries of living today. when the poor brain is cracking there's nothing like packing a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes" |
Codes starting with 0 are all generic codes required by law. This code says your cam position sensor impedance shows high values. It means your sensor is bad, or has a broken wire in the connector. The fix is to replace it. Clear the code, and drive.
Good info, thanks !
P0348 is telling you that the signal on sensor #2 is permanently high; most likely a failing cam position sensor. Fun to get at, but not a real problem to change out.
