afishkind's Avatar
Door panel off and found this rolling around at the bottom!
Removed my driver side door panel today to identify a rattle and do some maintenance prior to installing an AppBiz panel. At the inside bottom of the door .. near the stay .. I found this piece. Tried to identify it in the new parts catalog but no luck. All the door mechanisms have been working fine.
Help in identifying this part is appreciated.
Thanks!
1984 Carrera Coupe...Follow the Wad!
Per Dante: The darkest places in hell are reserved for those who maintain their neutrality in times of moral crisis.
Old 01-18-2014, 02:15 PM
Vulnerari Praesidio
Here you go:
http://forums.pelicanparts.com/porsche-911-technical-forum/738185-found-part-inside-my-drivers-door.html
There is more info in the forum.....
"Wisdom is knowing what to do next; virtue is doing it."
- David Starr Jordan
Old 01-18-2014, 02:20 PM
Broken part..It holds the spring in the roll up mechanism. The inside of the spring fits in the flats.
Bruce
Old 01-18-2014, 02:25 PM
I'm on this project myself. It's not the center of the spring, it's at the end of it, winding the spring more, providing more tension, and helping raise the window faster than it likely is moving now. I've got a great set of links at this post (plus a bunch of other door-related posts).
http://forums.pelicanparts.com/porsche-911-technical-forum/792312-meet-my-31-year-old-window-motor-winter-project.html
Old 01-18-2014, 02:33 PM
HarryD's Avatar
Does your window roll up and down ok? If so, most likely the PO had it break and replaced it but did not bother to fish out the broken part.
It is called a pivot pin and you can get replacements from our host.
Old 01-18-2014, 03:40 PM
HarryD's Avatar
Garment, are you sure? It looks like the center pivot pin that I needed to replace on both my windows a few years ago.
Old 01-18-2014, 03:42 PM
100%. See this thread which was my bible for this fix. In fact, I mistakenly ordered the center pin and had to send it back, it's not the pin for the end of the spring. You can even see the busted pin laying on the regulator in the pic.
http://forums.pelicanparts.com/porsche-911-technical-forum/664473-slow-window-fix.html
Old 01-18-2014, 05:53 PM
HarryD's Avatar
Garment, i see. When mine failed,they were the ones in the center. If you windows are working, no worries. If not take the regulators out and repair as needed. The necessary part will be obvious.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-18-2014, 10:19 PM
My "while I'm in there" journey started b/c the passenger window was out of parallel. When I took off the door card, and saw the tensioning pin was missing from the regulator...well, you know how things progress from there...
I bought 2 coupling nuts and bolts, I am quite certain that I have the same issue on the drivers door, hopefully the next time things go much more quickly.
Old 01-19-2014, 05:31 AM
afishkind's Avatar
Thanks all. I wasn't planning on removing window motor etc but I am now! Links were helpful.
Old 01-20-2014, 11:23 AM
