996 Exhaust Question
Porsche had an option for the exhaust that switched from quiet to 'Sport' utilizing a redirect valve of some sort, which would divert the exhaust through a different port into the muffler.
My question is: Since my car [2002 C4] does not have this option, can I just divert the inlet to the muffler to the 'Sport' port and block off the 'quiet' port in a permanent manner?
Thanks,
Drums
Old 01-19-2014, 08:59 AM
The diverter valves on the PSE (Porsche Sports Exhaust) are built into the PSE mufflers, as are the bypass chambers; so there is nothing on your car to change if you do not have the PSE:
Old 01-19-2014, 10:35 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
yes you can. It is called a Fister mod or gundo hack. Quite common and two ways to do it. Not exactly the way you mention it being done, but these are very common mods.
http://imganuncios.mitula.net/99_02_porsche_911_996_genuine_exhaust_muffler_w_fi ster_d_gundo_hack_mod_99433901812779210.jpg
http://forums.pelicanparts.com/uploads18/pse%2Bmod21299646615.jpg
The first way is the preferred way now.
Old 01-19-2014, 08:27 PM
Totally different. With welding equipment, anything is possible............
Old 01-20-2014, 02:24 AM
My local and friendly muffler shop did the job for 60.00....
I did the removal and installation in my garage.....
'99 996 Convertible
'94 MB E420 (Gone)
'86 MB 300E (Gone)
'87 MGM (Gone)
Old 01-24-2014, 06:42 AM
Did you get the memo?
onewhippedpuppy's Avatar
Same here, same price. Fantastic sound but almost stock sound levels when cruising.
This is the one referred to as the Fister mod. The Gundo hack is similar to the PSE mufflers, except it doesn't have the electric switch.
‘07 Mazda RX8
Old 01-27-2014, 10:57 AM
rattlsnak's Avatar
Just got mine done for free..
Old 01-27-2014, 05:47 PM
Old thread, I know. But, interestingly, this one shows two paths for the "bypass" pipe. One is straight between in/out and the other is a small loop. Is one better than the other? Also, there are size options. It looks like both of these are 1.5 in. Probably the way that I'll go. I basically can't hear my motor at all. My wife's stock Jag is way sportier in exhaust tone.
Todd
99 996 3.4-->3.6
Old 01-16-2017, 08:15 AM
Banned
Can i stick a set of used 997 sport exhaust mufflers on my 996 ??...
Old 01-18-2017, 04:12 PM
Did this last week. Couldn't be happier with the results. Mine look like pezuazo's above. No real change with normal driving, but put your foot into it and the exhaust sounds great.
Todd
99 996 coupe 3.4-->3.6
Old 02-09-2017, 06:50 PM
